[Geoserver-devel] Supporting JAI-EXT Enabling System property flag
Hi lists (sorry for cross-posting).
Since feature freeze is coming, we did some internal discussion about the capability to fully disable/enable JAI-EXT operations in GeoServer.
As you may have noticed, right now there is already a section in the JAI GUI page which allows to decide for each supported operation (add, multiply, mosaic, affine, …) whether to use the standard JAI one or the JAI-EXT’s one instead.
http://docs.geoserver.org/latest/en/user/webadmin/server/JAI.html
However, since JAI-EXT operations are relatively new, we would like to make sure they can be fully turned off (together with the related subsection in GeoServer GUI). Moreover, being a new feature coming with 2.8.x we would like to keep it disabled by default.
Server admins would turn it on with something like
-Dorg.geotools.jaiext.enabled=true at startup script.
Therefore, I’m going to add support for this flag.
(I will for sure open JIRA and pull requests for this)
Hope this helps.
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Thanks Daniele, Andrea mentioned it in the meeting yesterday so the change is expected.
Personally I have a bit of trouble keeping track of all these system property flags in GeoServer. But hesitate at adding them to the documentation as each seem to represent an internal experiment.
On 26 August 2015 at 09:19, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hope this helps.
Daniele
GeoTools-Devel mailing list
GeoTools-Devel@anonymised.coms.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Jody Garnett
On Wed, Aug 26, 2015 at 6:24 PM, Jody Garnett <jody.garnett@anonymised.com>
is expected.
I don't know how can you see most of them as "internal experiments".
Most of them are there to allow usage of a new system vs old system, either
allowing people in need to try the new system
that is known to not be as functional as the old one, or have the new one
work by default, but allow a fallback
to the old one in case something goes belly up when people actually try
stuff on their machines (as we all know, we
receive little/no testing from betas by the user base, so this is just
being cautious to me).
As for documenting them, I guess it's case by case, but most of the time,
we probably don't want to,
or we might want to lump them all in a "advanced and hopefully not useful"
section for the people
that want to go the extra mile, as the default is the choice making sense
for the majority of users.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Perhaps my language choice was poor, the difference between old/new system should mostly be hidden. The system property toggle allows someone deploying geoserver to swap between implementations if needed.
This is different from a Hint which explicitly makes the choice up to the programmer (although a default can be provided by a system property).
On 26 August 2015 at 10:08, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Wed, Aug 26, 2015 at 6:24 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
I don’t know how can you see most of them as “internal experiments”.
Most of them are there to allow usage of a new system vs old system, either allowing people in need to try the new system
that is known to not be as functional as the old one, or have the new one work by default, but allow a fallback
to the old one in case something goes belly up when people actually try stuff on their machines (as we all know, we
receive little/no testing from betas by the user base, so this is just being cautious to me).
As for documenting them, I guess it’s case by case, but most of the time, we probably don’t want to,
or we might want to lump them all in a “advanced and hopefully not useful” section for the people
that want to go the extra mile, as the default is the choice making sense for the majority of users.
Ing. Andrea Aime
@geowolf
Technical Lead
