I’ve putting some spare time towards adding support for TMS and XYZ file system structures for the GWC file blob store,
as this should allow pre-seeding and then publishing on static servers (something that popped up on list quite a few times).
The changes are hopefully nothing too invasive, and while working on it, I’ve also added some optimizations that
should speed up truncate of small areas over (very) large tile caches
PRs here:
https://github.com/GeoWebCache/geowebcache/pull/795
https://github.com/geoserver/geoserver/pull/3862
In GeoServer there is only a small change here (yes, it needs i18n):
Not sure if calling the google/osm layout xyz or slippy, suggestions?
Ah, if you are wondering about the difference between xyz/slippy and tms, see here (“The y coordinate”):
https://wiki.openstreetmap.org/wiki/TMS
Anyhow, reviews and comments welcomed
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
