[Geoserver-devel] svn reorg completed
The subversion reorganization is complete. It might be possible to just do an update by doing the following
* do a mvn clean
* do a mvn eclipse:clean
* clear out every other non-versioned file and directory under geoserver and configuration
However it is probably just easier to re-check out. svn switch might work too depending on your checkout.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
