[Geoserver-devel] Switched externals on 2.0.x
All externals on 2.0.x except data/citewfs-1.1-h2/workspaces still point to trunk.
Any objection to me changing them all? Or should this be left to module maintainers? (I'll do the app-schema one in any case [it points to GT trunk {naughty, naughty}].)
Changed externals will require everyone to delete the affected directories and re-checkout. Hudson maintainers, do your Hudson's "svn up" or "rm -rf; svn co"?
This happened before in 1.6.x, which was broken by changes to trunk paths because it had trunk externals. Should fixing externals be added to the branch procedure?
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
Yeah, I think that should be fixed.
It does svn up. We might need to wipe out the checkouts once manually
for this change (not such a big deal).
If you go ahead close to the italian morning I can fix the build shortly
after when I wake up (I'm around now too, but it's late for you, isn't
it?)
Yep, good idea. You do it? :slight_smile:
Andrea Aime
OpenGeo - http://opengeo.org
to trunk.
it?)
Not too late. I'll do it now.
OK, will do.
it?)
It is done. Fresh checkout succeeded. I will make a test build, but it looks good.
OK, will do.
The long-term solution, which requires all svn clients to be version 1.5 or later, is to use relative externals:
http://subversion.tigris.org/svn_1.5_releasenotes.html#externals
Relative (internal) externals would require no maintenance when branching. Only external externals (yes, I am turning into Donald Rumsfeld) would require an absolute URI (I use one of these in app-schema to get GeoTools app-schema test data for integration tests).
Kind regards,
it?)
It seems Hudson had no issues with the change, the build worked fine.
OK, will do.
Yeah, makes sense. The current stable svn client is 1.6.
I think most Linux distributions are using 1.5 by default
However people using CentOS are still on svn 1.4 afaik.
Well, let's make a poll :slight_smile:
Andrea Aime
Good. My fresh checkout and build also worked fine.
For the benefit of other developers, the reason why a fresh checkout is essential is that "svn up" will not refresh a changed external URL, which is only followed at chekout time. A working copy will silently retain a checkout from an old URL. In this case, that would leave you with a mix of 2.0.x and trunk. Not good, not good!
Kind regards,
Heh, doing a full checkout every time is too expensive, our build boxes
are not that powerful.
I'll do a manual rm -rf in the Hudson checkout
Andrea Aime
Agreed. My build bots also "svn up"; it is usually more than enough for normal activity, much more efficient, and only vulnerable to structural changes such as this one, which are infrequent. We should not waste CPU power or otherwise unnecessarily deplete our natural resources.
Thanks!
I would like to retract this baseless assertion! Reading the subversion docs ("Externals Definitions") indicates that "svn up" does notice and recursively update a changed svn:externals definition. Furthermore, I have confirmed this behaviour in practice using a test repo.
The probably reason I was seeing no apparent update of the externals with "svn up" was that the old and new contents were identical, having not deviated since the branch, and svn is clever enough to notice this and detect that there is nothing to do. Cleverer than me, apparently.
Kind regards,
