[Geoserver-devel] Switching a real application (GeoServer) from MapContext/MapLayer to MapContent/Layer
for the second time in a week I'm cross posting on geotools and
geoserver list for a topic that is of interest of both communities.
Some months ago, right before the GeoTools 2.7.0 release, Jody
(and Michael too I guess?) made and implemented this proposal:
http://docs.codehaus.org/display/GEOTOOLS/MapContext+Refactor
The proposal was not fully executed as the renderer still works against
MapContext and friends.
Now Michael has worked a patch to complete the proposal, on which
he is waiting for in order to get some work done on the swing module:
http://jira.codehaus.org/browse/GEOT-3565
The original patch deprecated just MapContext. However, since MapContent
is made of Layer classes (which is actually a hierarchy or type specific
classes, see attached screenshot), it also makes sense to deprecate
MapLayer (which is-not-a Layer).
This generates a number of deprecated usages for applications that
work a lot with maps.
Most applications that just setup a map and have it rendered
will have it somewhat easy, just change the part that builds the
map, however others, more complex ones will be hit harder.
GeoServer is one such example, MapContext and MapLayer are not
just built to feed StreamingRenderer, but they are also used later
to analyze the structure of the map and fed into at least five custom
renderer, the kml one, the streaming svg one, rss and atom, and
the html image map one.
Also the testing code sets up and uses a lot those classes too.
I've spent all the day performing a tentative switch of the code base
and attached the resulting patch here:
http://jira.codehaus.org/browse/GEOS-4597
As you can see the patch is not small, weighting 121KB, and affects
pretty much all of the wms module, plus the CRS area of validity
preview in the GUI modules, gwc integration, html image map output
format and the python module.
The patch basically does two things:
- switches WMSMapContext to be a MapContent extension
- switches all MapLayer usage to using Layer subclasses
The first is mechanical, a lot of getAreaOfInterest/setAreaOfInterest
needed to be changed to getViewport().getBounds/setBounds.
The latter is more of black magic, and I probably made mistakes
during the conversion, especially in the KML generation subsytem
which was the most heavily hit.
The latter is kind of a problem because all of the code using layers
in GeoServer assumes that:
- all layers are uniform unless otherwise needed
- every layer has a query
- every layer has a style
- every layer can return a feature source
The "Layer" hierarchy breaks all of the above assumptions.
Throughout the code I had to make guess on what kind of layer
the code was meant to work with (feature? grid coverage reader?
wms layer?) and perform casts accordingly, of course with
quite the number of "instanceof" checks spread around.
Now, the patch survives a build and some interactive testing.
I did not, however, check KML generation: there are a million
different code paths and configurations and I'm not well
setup to test them on Linux (GE does not really work well
here).
All the patch needs a review, but the KML part really needs
a detailed one along with tester willing to check out all of the
usage cases (network links, superoverlays, cached regionation
hierarchies, extrusion and time support, gwc integration, and so on).
Need help on this one, I'm not going to do it myself.
The patch also has maintenance implications for GeoServer: it will
make harder to backport to the stable branch any patch affecting
WMS, as we'll have to write it for Layer on trunk and recode it
for MapLayer on 2.1.x.
In particular it will very likely intersect with my time/elevation
work, making the first patch landing require reworks in the other.
Anyways, during the switch I took down notes about things that
bite me during the switch and probably need improvement on
the GeoTools side:
- GridReaderLayer constuctors force one to specify the title to
  pass also the parameters. Title might not be always needed,
  but some readers will not give the best without custom param
  settings. Please add a constructor wtih reader, style and params
- getAreaOfInterest() replacement is getViewport().getBounds(),
  made me stare for a good five minutes at the API looking for
  it though. I guess we need an upgrade guide and this one should
  be cited
- getViewport().getBounds() returns null if not explicitly initialized.
  That also got me into quite a bit of trouble, the old classes
  would initialize the bounds to the layer bounds if no manual
  initialization was made.
  Please get back this behavior, otherwise upgraders will have to
  fight quite a bit of NullPointerExceptions
- GridCoveageLayer and GridReaderLayer really need a GridLayer
  base class, right now to recognize if a layer is raster one has
  to make two instanceof, two casts, and if the code relying on the
  ability to extract a feature source out of the layer is hard to
  change, two casts to call the toFeatureCollection() method that
  both expose
Opinions, suggestions, concerns... even flames if you really need to...
welcomed!
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
(attachments)
Thanks to both Andrea and Micheal for resuming this work (the original tasks stalled out waiting on some rendering optimisation which are now done).
Andrea I have created “sub issues” here to track the API requests from your email:
I have also added this jira to the proposal page etc…
Jody Garnett
On Sunday, 5 June 2011 at 3:30 AM, Andrea Aime wrote:
for the second time in a week I’m cross posting on geotools and
Quick Question Andrea:
The other renderers in GeoServer - do they implement the GTRender interface (if so I would like to make a note in the docs).
Jody
On Sun, Jun 5, 2011 at 1:59 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Nope they don't. In GeoServer there are a number of things that are pure
streaming transformers, they take one or more objects (map context,
feature collections, other EMF stuff) and transform them into some format
which is written directly to a stream.
All of the KML, RSS, Atom, streaming SVG and HTML image map things
fall in that category.
They are "encoders" of sorts, we don't have such a general concept in GeoTools
if you exclude the various forms XML Encoder/Transformer classes.
In GeoServer they are generally captured by the Response hierarchy:
http://svn.codehaus.org/geoserver/trunk/src/ows/src/main/java/org/geoserver/ows/Response.java
The Response is part of the dispatch system, which takes a HTTP requests, parses
it into an object form representation, finds the service that can
answer to it, grabs
an object generated by the service and passes it over to the Response
for encoding
to some serialization format.
A response is thus responsible for taking an "object", saying it can
handle it, say
which mime types it can generate, and do the encoding if the object type and
the output mime type match was was requested by the caller, all in the context
of the current "Operation", which summarizes both the parsed http
request parameters,
the service object that was chosen and the method to call on the service object.
Ing. Andrea Aime
Tech lead
Looks like great work Andrea. Kudos. I haven’t had a chance to review the patch yet (on the road atm) but will try to provide some feedback.
As for KML… its indeed troubling. KML seems to be going the way of unsupported these days… i wonder if it is time to think about a demotion into a community module in case a maintainer wants to step up.
As for maintenance after the big switch again problematic… seems like a tough call. Not much we can do I guess… past backporting the work to stable branch but this by definition seems suited to only trunk.
2c.
On Sat, Jun 4, 2011 at 11:30 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
I’ve spent all the day performing a tentative switch of the code base
  • switches WMSMapContext to be a MapContent extension
  • switches all MapLayer usage to using Layer subclasses
  • all layers are uniform unless otherwise needed
  • every layer has a query
  • every layer has a style
  • every layer can return a feature source
The “Layer” hierarchy breaks all of the above assumptions.
quite the number of “instanceof” checks spread around.
different code paths and configurations and I’m not well
here).
Need help on this one, I’m not going to do it myself.
WMS, as we’ll have to write it for Layer on trunk and recode it
the GeoTools side:
  • GridReaderLayer constuctors force one to specify the title to
  • getAreaOfInterest() replacement is getViewport().getBounds(),
    be cited
  • getViewport().getBounds() returns null if not explicitly initialized.
  • GridCoveageLayer and GridReaderLayer really need a GridLayer
    both expose
Opinions, suggestions, concerns… even flames if you really need to…
welcomed!
Ing. Andrea Aime
Tech lead
Simplify data backup and recovery for your virtual environment with vRanger.
Installation’s a snap, and flexible recovery options mean your data is safe,
secure and there when you need it. Discover what all the cheering’s about.
Get your free trial download today.
http://p.sf.net/sfu/quest-dev2dev2
Geotools-devel mailing list
Geotools-devel@anonymised.coms.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Justin Deoliveira
OpenGeo - http://opengeo.org
On Sun, Jun 5, 2011 at 6:52 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Looks like great work Andrea. Kudos. I haven't had a chance to review the
Cool thanks!
As for KML... its indeed troubling. KML seems to be going the way of
unsupported these days... i wonder if it is time to think about a demotion
Yep, I was thinking about the same.
We have code that assumes KML is there, so kicking it back in extension
or community may not be as immediate as grabbing the classes and
moving them to another module (for example the layer preview GUI assumes
KML is there).
It's kind of a pity though, to have the KML module regress while competition
(MapServer) starts to have some KML support.
At the same time it does not seem like there is many people interested in
maintaining it, we'll see.
Anyways, this is a discussion we can have in a separate thread, without
having to involve also the GeoTools developers.
As for maintenance after the big switch again problematic... seems like a
tough call. Not much we can do I guess... past backporting the work to
Agreed, definitely not suited to backports.
Ing. Andrea Aime
Tech lead
Technically these classes are in place in the 2.7.x branch; so after trunk has had a chance to work with the change for a while the work could be backported for ease of maintenance.
Jody
On Mon, Jun 6, 2011 at 12:33 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Yep, API wise they could be backported with some changes (e.g.,
StreamingRenderer
does not have a setMapContent there).
However we cannot backport a set of changes that are probably breaking
KML support in unknown/unexpected ways onto a stable series
Ing. Andrea Aime
Tech lead
