[Geoserver-devel] switching windows hudson to send a single mail
Any objections to this? If the appropriate people want to give me access to the build box I would be happy to try and do this.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Sure, go ahead. The login is the same as the main build box.
I could not see any specific setting, hope you have better luck :slight_smile:
Andrea Aime
Cool. And yeah, it is because it is a maven specific job it seems. Any objections to havign it mirror the other hudson as a freestyle build? The maven build seems easier to maintain but my fear is that spamming the dev list will cause people to ignore it.
Justin Deoliveira
Actually the main hudson box is using regular maven builds too it seems:
http://hudson.opengeo.org/hudson/job/geotools-trunk/configure
May be just the different Hudson version.
If we switch away I also think we'll loose the unit testing reporting
that made people ask we upgrade the main build box as well.
Maybe it's better to ask on the Hudson mailing list if it's possible
somehow to avoid this mail flood without throwing away the other
benefits?
Andrea Aime
Ok, seems I was confused. I could have sworn I set up the original hudson like that. Seems I am losing it. But yeah, i guess it is time to dig deeper into the hudson docs or configuration files to try and find the option for a single mail.
benefits?
Justin Deoliveira
