[Geoserver-devel] Tabs to spaces discussion
Moving the discussion for https://github.com/geoserver/geoserver/pull/1598 to the mailing lists.
This is a non-functional change that has the potential to cause merge conflicts in some percentage of the currently open pull requests.
This change has been discussed in the past, but has generally been considered too much of a hassle.
A change of this magnitude will likely always be a hassle to deal with, so we might as well do it eventually. Given that we recently branched of 2.9.x, we are in a relatively good position to do this now. Unfortunately, there are also a lot (23) of Pull Requests open against GeoServer right now, which makes this a less attractive change at this point.
Torben
As a committer, a former PSC member, and someone who hates tabs as much as anyone, I would give this the most negative vote I could :slight_smile: While I do hate having to deal with tabs in source files it’s a small burden compared to the mess that results from trying to merge into a file where formatting has changed.
I would say open pull requests is probably not a great indication of how much code there is out there branched off of GeoServer. If I look in my local repository i have a lot of unmerged branches. There are probably a lot of tickets with patch files on them, etc…
I’m all for enforcing spaces on new files added to the code base but I think trying to go back and re-format existing files is opening up a can of worms that probably isn’t worth it.
$0.02
On Fri, May 13, 2016 at 4:44 PM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j_______________________________________________
Geoserver-devel mailing list
chiming in with my own point of view on the matter.
Yes, I agree that mixed tabs are a significant nuisance, some parts of the code are quite messy because of that (although I’d normally
be more concerned about GeoTools than GeoServer in terms of tabs).
Personally I am not against the change, provided it’s applied on all active branches to avoid making bug fix backports harder than strictly necessary.
Justin raises a fair point about this making it harder to merge code from outside, but I’m not sure I agree with the conclusion.
Jira wise, I’ve been telling people that we do not accept patches anymore for at least a couple of years.
Now, we still have some, and it’s not easy to locate all of them, I’ve tried here by checking that the word “patch” is in the
ticket and that we have an attachment, unfortunately this also matches tickets having an attachment and in which we ask
for a patch:
https://osgeo-org.atlassian.net/issues/?jql=project%20%3D%20GEOS%20AND%20status%20%3D%20Open%20AND%20text%20~%20patch%20AND%20NOT%20attachments%20is%20EMPTY%20ORDER%20BY%20created%20DESC
That said… nobody is applying this patches anyways so… should we be concerned about them? Most of them do
not apply anyways of how old they are. If we had a champion that would process them and turn them into
pull request, well, that would be amazing of course :slight_smile:
In general, I’d ask if people with significant work in progress could have a look at the tabs pull request and report if they are going
to be affected in a significant way. Raise of hands please, are we going to make your life hell by merging this patch?
In the end I believe we should be concerned about stuff that is due to get merged soon-ish, our code changes fast, keeping up
a long lived branch is like running after a train that would never stop regardless.
On Sat, May 14, 2016 at 12:42 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
