jive
May 8, 2022, 8:24pm
1
I have run into some conflicts trying to sync tags between remote repos:
= [up to date] 2.16.2 → 2.16.2
! [rejected] 2.16.3 → 2.16.3 (would clobber existing tag)
= [up to date] 2.16.4 → 2.16.4
= [up to date] 2.20.2 → 2.20.2
! [rejected] 2.20.4 → 2.20.4 (would clobber existing tag)
= [up to date] 2.3-RC1 → 2.3-RC1
I do not know if this is just me? Not sure how they got out of sync?
Jody Garnett
Hi Jody,
how are you getting that?
I’ve tried with a “git fetch -t”, getting no errors:
git fetch -t
remote: Enumerating objects: 2264, done.
remote: Counting objects: 100% (1560/1560), done.
remote: Compressing objects: 100% (478/478), done.
remote: Total 2264 (delta 1070), reused 1504 (delta 1030), pack-reused 704
Ricezione degli oggetti: 100% (2264/2264), 688.85 KiB | 1.94 MiB/s, fatto.
Risoluzione dei delta: 100% (1074/1074), completato con 86 oggetti locali.
Da github.com :geoserver/geoserver
3e7e8c2bcd…0f33e1f6b9 main → geoserver/main
b101163df4…58a6db824b 2.19.x → geoserver/2.19.x
42cfdb1d74…0afcf2a7d3 2.20.x → geoserver/2.20.x
e48d0f9cdc…6dcc807326 2.21.x → geoserver/2.21.x
[nuovo riferimento] refs/pull/5873/head → geoserver/pr/5873
[nuovo riferimento] refs/pull/5874/head → geoserver/pr/5874
[nuovo riferimento] refs/pull/5875/head → geoserver/pr/5875
[nuovo riferimento] refs/pull/5876/head → geoserver/pr/5876
[nuovo riferimento] refs/pull/5877/head → geoserver/pr/5877
[nuovo riferimento] refs/pull/5878/head → geoserver/pr/5878
[nuovo riferimento] refs/pull/5879/head → geoserver/pr/5879
[nuovo riferimento] refs/pull/5880/head → geoserver/pr/5880
[nuovo riferimento] refs/pull/5881/head → geoserver/pr/5881
[nuovo riferimento] refs/pull/5882/head → geoserver/pr/5882
[nuovo riferimento] refs/pull/5883/head → geoserver/pr/5883
[nuovo riferimento] refs/pull/5884/head → geoserver/pr/5884
[nuovo riferimento] refs/pull/5885/head → geoserver/pr/5885
[nuovo riferimento] refs/pull/5886/head → geoserver/pr/5886
[nuovo riferimento] refs/pull/5887/head → geoserver/pr/5887
[nuovo riferimento] refs/pull/5888/head → geoserver/pr/5888
! [rifiutato] 2.20.2 → 2.20.2 (sovrascriverebbe il tag esistente)
[nuovo tag] 2.21-M0.1 → 2.21-M0.1
[nuovo tag] 2.21-RC → 2.21-RC
[nuovo tag] 2.21.0 → 2.21.0
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
jive
May 23, 2022, 5:16pm
3
I honestly do not know how I got that, my theory is:
geocat/geoserver syncs with geoserver/geoserver (perhaps including tags)
when we re-run builds a revision may be re-tagged by the release process
some time in the future if I am unlucky I get a tag conflict
So yeah i suspect this is just me.
Jody Garnett
jive
May 24, 2022, 3:59am
4
Okay, Ian unintentionally ran an experiment by re-tagging 2.21.0 to include an additional fix: 135494dccc2c50ba4d0ddcb110a55339081163a1
This gave me the same error since I had the previous 2.21.0 tag locally.
Jody Garnett
Jody Garnett
The only “issue” I see is for 2.20.2 when I do git fetch -t
Not sure what’s going on there.
Ian
Ian Turton
