Trying to implement the getfeatureinfo operation using templates i have
run into an issue. I should also state that I am attempting to use the
same template for getfeatureinfo as for kml placemark descriptions.
Currently the template stuff is written to take a single feature or an
entire feature collection to process. Which is nice because in some
cases you want to pass in a single feature ( like with a kml placemark
), and other cases you want to pass in a feature collection ( like with
getfeatureinfo ).
The problem is on the template writers side. If I want to create a
single template for all these different output formats, i don't want to
have to worry about having to check if i was passed a single feature, or
an entire collection.
So... i see a couple of solutions for this problem.
1. Make the user create two templates ( boo )
2. Make the user do the check in the template ( boo hiss )
3. For every type of template we support specify if it takes a single
template or a collection as input ( yay! )
3 makes the most sense to me, and i apologize if i am stating the
obvious. However, #3 has circumstances for the getfeatureinfo operation
if we want to reuse the kml template. Since the kml stuff always takes a
single feature, the default template for it outputs a simple html table
with headings for every single attribute name, and the single row for
the values. Great!!
But lets say a getfeatureinfo operation hits multiple features, directly
applying the same template will produce a table in which the attributes
names are reproduced for each row.. blah!!
Now since the query in the getFeatureInfo op is a single x/y value it
matches a single feature *most* of the time but as we know its pretty
easy to come up with a case where multiple features are matched.
So... unsure how to proceed. Any feedback would be welcomed.
Can you do a three part template?
- header
- result - used to write out each feature
- footer
That way you do not have to care if they are doing more than one feature or not?
Jody
getfeatureinfo ).
the values. Great!!
I am already lost. Why do you need to reuse that template instead
of copying it and adapting it to the realities of GetFeatureInfo?
(more on the different nature later).
As a rule of thumb, templates will fall into user hands, so the
simpler and to the point they are, the better imho (so I agree filling
them with ifs is bad).
It's harder than that. You'll have to set up multiple tables.
GetFeatureInfo will catch feature from multiple levels, with different
schemas, so I guess you'll want to set up a table for each level.
From the template params point of view, I guess it would be ok to
provide a list of feature collections, each coming from a different
layer. Am I missing anything?
I meant that I think it would be beneficial to have the user maintain a
single "description template" ( a little blurb of html that describes a
feature ) which could be used for both. But indeed this may not be a
case where that is possible.
We could do this. I guess the only downside is it gets more complicated
when the user wants to create their own template. Another tradeoff...
