During work on GSIP 120 I detected that the file
src/main/src/test/java/org/geoserver/data/test/security.zip
does not contain the default “layers.properties” file.
Should I simply add it as part of GSIP 120 or is it better to create a JIRA issue, commit to master and backport to 2.6
CheersChristian
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
On Thu, Oct 23, 2014 at 4:09 AM, Christian Mueller <
does not contain the default "layers.properties" file.
I don't imagine it would hurt anything to just add it as part of your GSIP
120 work... although I always think it is a better idea to make more
granular/specific changes if possible. Easier to track. Your call
Christian.
Christian
Geoserver-devel mailing list
Justin Deoliveira
VP Engineering | Boundless <http://boundlessgeo.com/>
jdeolive@anonymised.com
@boundlessgeo <http://twitter.com/boundlessgeo/>
