I am working offline these days and am having to do a couple of patches to make it through a "maven build -O" ...
I was surprised to find that GeoServerOnlineTest no longer checks the local geoserver (this is a big plus when working away from the big bad internet).
We can do two things:
a) Restore what we had 1) run against localhost default geoserver install + if not available run against refractions test geoserver
b) Explicitly leave GeoServerOnlineTest working against the refractions test geoserver + create GeoServerLocalTest
I have implemented b) and can commit it has the advantage of working with the -O flag, but we will perform the same tests "twice" when building normally (the whole point being that if a local service is available we can avoid external tests).
The other thing I found was that with the latest GeoServer PR1 install our tests no longer work "out of the box" ...
Does GeoServe still ship w/ data? I think it does ... but the following fail:
1 - testFeatureReaderWithFilterBBoxGET(org.geotools.data.wfs.GeoServerLocalTest)
junit.framework.AssertionFailedError: must have 1 feature -- fair assumption
at junit.framework.Assert.fail(Assert.java:47)
at junit.framework.Assert.assertTrue(Assert.java:20)
at org.geotools.data.wfs.WFSDataStoreReadTest.doFeatureReaderWithBBox(WFSDataStoreReadTest.java:184)
at org.geotools.data.wfs.GeoServerOnlineTest.testFeatureReaderWithFilterBBoxGET(GeoServerOnlineTest.java:147)
2 - testFeatureReaderWithFilterBBoxPOST(org.geotools.data.wfs.GeoServerLocalTest)
at org.geotools.data.wfs.GeoServerOnlineTest.testFeatureReaderWithFilterBBoxPOST(GeoServerOnlineTest.java:153)
So perhaps the default data w/ geoserver has changed and broken these tests? Any advice on how you guys want to deal w/ this one?
