[Geoserver-devel] The documentation is not getting deployed anymore?
I am looking at the GeoServer documentation, it seems it’s outdated, for example the new jpeg-png format
is not available in the online docs, but it’s there in github:
http://docs.geoserver.org/latest/en/user/services/wms/outputformats.html
https://github.com/geoserver/geoserver/blob/master/doc/en/user/source/services/wms/outputformats.rst
Traditionally the docs were deployed at the end of a normal build, and I still see it copying over files in the
build logs:
Build finished. The HTML pages are in build/html.
+ rm -rf /var/www/geoserver/origin/master/doc/en/user
+ cp -r build/html /var/www/geoserver/origin/master/doc/en/user
Wondering if this was sufficient once to get the docs to update, but it’s not anymore for some reason?
Has the docs server been modified/moved lately?
I believe Jody was seeing a similar problem for the geotools docs, not sure if that got fixed or not in
the meantime, the thread over there is not clear on the outcome (besides setting up a new job, that is,
it’s not clear if the docs are now getting updated).
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
The geotools docs were updated - I am not sure what changed. Chris do you know if anything more is needed?
On 6 July 2016 at 03:36, Andrea Aime <andrea.aime@anonymised.com> wrote:
build logs:
Ing. Andrea Aime
@geowolf
Technical Lead
Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T Park in San
Francisco, CA to explore cutting-edge tech and listen to tech luminaries
present their vision of the future. This family event has something for
everyone, including kids. Get more information and register today.
http://sdm.link/attshape
Geoserver-devel mailing list
Jody Garnett
Hey Jody,
Not that I am aware of.
Chris
On Wed, Jul 6, 2016 at 3:21 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
build logs:
Ing. Andrea Aime
@geowolf
Technical Lead
Christian Del Pino
DevOps Engineer
Boundless | www.boundlessgeo.com
Email: cdelpino@anonymised.com
Hold on I think Kevin was in there publishing some of the older docs recently…
build logs:
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Looking at build 2600/consoleFull :
  • rm -rf /var/www/geoserver/origin/master/doc/en/user
  • cp -r build/html /var/www/geoserver/origin/master/doc/en/user
  • rm -rf /var/www/geoserver/origin/master/doc/en/developer
  • cp -r build/html //var/www/geoserver/origin/master/doc/en/developer
  • rm -rf /var/www/geoserver/origin/master/doc/en/docguide
  • cp -r build/html /var/www/geoserver/origin/master/doc/en/docguide
Other than the developer guide having “//” I do not see anything wrong…
build logs:
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
On Wed, Jul 6, 2016 at 9:59 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
<http://ares.boundlessgeo.com/jenkins/view/geoserver/job/geoserver-master/2600/consoleFull&gt;
+ rm -rf /var/www/geoserver/origin/master/doc/en/developer
+ cp -r build/html //var/www/geoserver/origin/master/doc/en/developer
+ rm -rf /var/www/geoserver/origin/master/doc/en/docguide
+ cp -r build/html /var/www/geoserver/origin/master/doc/en/docguide
Other than the developer guide having "//" I do not see anything wrong...
The copy sort of assumes ares and docs are the same box though... or not?
Are they? If not, how are the files supposed to get on docs?
Also the paths do not seem to match, the documentation on docs is at:
while the path the stuff is being copied to is master/doc/en/user
Ing. Andrea Aime
@geowolf
Technical Lead
Maybe we have both master and 2.9.x copying to the same place?
The copy sort of assumes ares and docs are the same box though… or not?
Ing. Andrea Aime
@geowolf
Technical Lead
That’s easy enough to check, just look at the build logs…
On master:
On 2.9.x
  • rm -rf /var/www/geoserver/origin/2.9.x/doc/en/user
  • cp -r build/html /var/www/geoserver/origin/2.9.x/doc/en/user
So… not in the build itself. I still don’t understand how these
paths end up being mapped on docs.geoserver.org though,
getting to know that might help clarify the situation.
Speaking of which… at the bottom of our documentation pages for master and 2.9.x on docs.geoserver.org it says:
© Copyright 2016, Open Source Geospatial Foundation. License Creative Commons Attribution. Last updated on Jun 28, 2016. Created using Sphinx.
© Copyright 2016, Open Source Geospatial Foundation. License Creative Commons Attribution. Last updated on Jun 27, 2016. Created using Sphinx.
Seems like whatever was copying the documentation from the build output to docs.geoserver.org is not working anymore.
Indeed if you go here (damn slow, but working if you’re patient) you’ll get the latest master build instead (looked at the path where the docs
are copied and figured out where they are exposed by apache):
http://ares.boundlessgeo.com/geoserver/origin/master/doc/en/user/
On Sat, Jul 9, 2016 at 12:53 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
On Thu, Jul 7, 2016 at 10:16 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Wed, Jul 6, 2016 at 9:59 PM, Jody Garnett <jody.garnett@anonymised.com403…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
This page on master (http://docs.geoserver.org/latest/en/user/data/database/primarykey.html) should have changed on June 30th (https://github.com/geoserver/geoserver/commit/f424dd342cf3931bf293471e84a58ed410872304). While yesterday’s change to the GeoTools docs has gone out fine (http://docs.geotools.org/latest/userguide/library/render/faq.html)
Ian
On master:
On 2.9.x
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Jul 6, 2016 at 9:59 PM, Jody Garnett <jody.garnett@anonymised.com…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
I took a stab at this. Looking at a build from Jun 28 we have:
[geoserver-master] $ /bin/sh -xe /tmp/hudson6430242953085261747.sh
+ VER=master
+ BASE=/var/www/geoserver/master/doc/en
+ [ -e /var/www/geoserver/master/doc/en ]
+ cd doc/en/user
+ make clean html
rm -rf build/*
mkdir -p build/html build/doctrees
sphinx-build -b html -d build/doctrees   source build/html
A build from Jun 30 has:
[geoserver-master] $ /bin/sh -xe /tmp/hudson1759667221082312760.sh
+ VER=origin/master
+ BASE=/var/www/geoserver/origin/master/doc/en
+ [ -e /var/www/geoserver/origin/master/doc/en ]
+ cd doc/en/user
+ make clean html
rm -rf build/*
So (as Ben surmised) it appears that we are getting the wrong value for VER - origin/master instead of master
VER is being populated from GIT_BRANCH, which appears to come from the Jenkins Git plugin.
I am not sure why this behvior has changed.
Chris - is it possible there were some updates to the ares jenkins recently?
I have found a workaround here: http://stackoverflow.com/questions/20541609/how-to-receive-local-git-branch-name-with-jenkins-git-plugin and am applying it the ares builds. I will see if this fix works shortly.
Andrea - the doc redirects are configured on docs.geoserver.org - see step 7 of http://docs.geoserver.org/latest/en/developer/release-guide/index.html#post-the-documentation
Basically, a proxy is used to map stable, maintenance, latest, etc. to specific locations on ares.
Torben
Ian
On master:
On 2.9.x
Ian Turton
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Torben,
A plugin was installed recently to for the Geogig team. Build Reports/jacoco.
The git plugin was updated, per request, not too long ago. Not sure if any of these would cause the issue at hand?
Chris
On Tue, Jul 12, 2016 at 5:09 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
+ VER=master
+ cd doc/en/user
+ make clean html
rm -rf build/*
+ VER=origin/master
+ cd doc/en/user
+ make clean html
rm -rf build/*
Torben
Ian
On master:
On 2.9.x
Ian Turton
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Christian Del Pino
DevOps Engineer
Most likely updating the git plugin slightly changed the behavior of the ${GIT_BRANCH} macro, appending origin/.
Assuming the timeline fits, that would explain why this started happenting.
Torben
On Tue, Jul 12, 2016 at 2:23 PM, Christian Del Pino <cdelpino@anonymised.com> wrote:
Hi Torben,
Chris
+ VER=master
+ cd doc/en/user
+ make clean html
rm -rf build/*
+ VER=origin/master
+ cd doc/en/user
+ make clean html
rm -rf build/*
Torben
Christian Del Pino
DevOps Engineer
Ian
On master:
On 2.9.x
Ian Turton
On Sat, Jul 9, 2016 at 12:53 AM, Jody Garnett <jody.garnett@anonymised.com.403…> wrote:
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
The jenkins builds have finished, and the docs appear to be getting updated correctly now.
I have also added a “geoserver-master-nightly-docs” task, that builds and deploys the master docs nightly, such that we can build & deploy docs seperately from the rest of geoserver. I can add equivalent builds for 2.9.x and 2.8.x as needed.
Torben
On Tue, Jul 12, 2016 at 2:28 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Hi Torben,
Chris
+ VER=master
+ cd doc/en/user
+ make clean html
rm -rf build/*
+ VER=origin/master
+ cd doc/en/user
+ make clean html
rm -rf build/*
Torben
Christian Del Pino
DevOps Engineer
Ian
On master:
On 2.9.x
Ian Turton
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks for fixing everything Torben.
Could we change that to geoserver-master-docs and git it to watch a section of the git repo? And remove the doc build from geoserver-master … this would allow doc fixes to deploy faster.
And not trigger a full build when only the docs change.
Jody Garnett
On 12 July 2016 at 15:34, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity planning
reports.http://sdm.link/zohodev2dev
Torben
Hi Torben,
Chris
+ VER=master
+ cd doc/en/user
+ make clean html
rm -rf build/*
+ VER=origin/master
+ cd doc/en/user
+ make clean html
rm -rf build/*
Torben
Christian Del Pino
DevOps Engineer
Ian
On master:
On 2.9.x
Ian Turton
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Torben,
geoserver-master-live-docs seems to be running every two minutes most of the time. I found this surprising:
http://ares.boundlessgeo.com/jenkins/view/geoserver/job/geoserver-master-live-docs/
Kind regards,
Ben.
correctly now.
I have also added a "geoserver-master-nightly-docs" task, that builds and
Torben
Torben
Hi Torben,
Reports/jacoco.
Chris
+ VER=master
+ cd doc/en/user
+ make clean html
rm -rf build/*
+ VER=origin/master
+ cd doc/en/user
+ make clean html
rm -rf build/*
Jenkins Git plugin.
recently?
step 7 of
Torben
While yesterday's change to the GeoTools docs has gone out fine (
Ian
wrote:
That's easy enough to check, just look at the build logs...
On master:
On 2.9.x
+ rm -rf /var/www/geoserver/origin/2.9.x/doc/en/user
+ cp -r build/html /var/www/geoserver/origin/2.9.x/doc/en/user
So... not in the build itself. I still don't understand how these
Speaking of which... at the bottom of our documentation pages for
Commons Attribution. *Last updated on Jun 28, 2016*. Created using
Sphinx.
Commons Attribution. *Last updated on Jun 27, 2016*. Created using
Sphinx.
Indeed if you go here (damn slow, but working if you're patient)
you'll get the latest master build instead (looked at the path where the
docs
+ cp -r build/html
wrong...
not?
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica
e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
The information in this message and/or attachments, is intended
solely for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
Protection Code).Any use not in accord with its purpose, any disclosure,
reproduction, copying, distribution, or either dissemination, either whole
or partial, is strictly forbidden except previous formal approval of the
named addressee(s). If you are not the intended recipient, please contact
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be confidential
or proprietary in nature or covered by the provisions of privacy act
luminaries
Ian Turton
Christian Del Pino
DevOps Engineer
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
This geoserver-master-live-docs build is also running in the same workspace as geoserver-master and is permitted to run concurrently. I do not think this is a good idea. I suspect that their git updates are conflicting.
Kind regards,
Ben.
On 24/07/16 00:54, Ben Caradoc-Davies wrote:
Torben,
Kind regards,
Ben.
correctly now.
Torben
Torben
Hi Torben,
Reports/jacoco.
Chris
+ VER=master
+ cd doc/en/user
+ make clean html
rm -rf build/*
+ VER=origin/master
+ cd doc/en/user
+ make clean html
rm -rf build/*
Jenkins Git plugin.
recently?
step 7 of
Torben
Ian
On master:
On 2.9.x
Sphinx.
Sphinx.
docs
+ cp -r build/html
wrong...
not?
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
luminaries
Ian Turton
Christian Del Pino
DevOps Engineer
Director
New Zealand
Torben,
the Jenkins geoserver-master-live-docs job is often re-triggering every 90 seconds or so. I have disabled it until the concurrency and polling issues are resolved.
Kind regards,
Ben.
conflicting.
Kind regards,
Ben.
Torben,
Kind regards,
Ben.
updated
correctly now.
and
Torben
Director
New Zealand
Thanks Ben, I was working on trying to get them only to build when the “doc” folder had changed (checking every two mins allowed it to be more responsive). I also added a documentation category, allowing the doc build to run concurrently with the maven builds.
I see your email, and yeah will put it in a different workspace.
On 23 July 2016 at 05:54, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Torben,
Kind regards,
Ben.
correctly now.
Torben
Torben
Hi Torben,
Reports/jacoco.
Chris
  • VER=master
  • BASE=/var/www/geoserver/master/doc/en
  • [ -e /var/www/geoserver/master/doc/en ]
  • cd doc/en/user
  • make clean html
    rm -rf build/*
  • VER=origin/master
  • BASE=/var/www/geoserver/origin/master/doc/en
  • [ -e /var/www/geoserver/origin/master/doc/en ]
  • cd doc/en/user
  • make clean html
    rm -rf build/*
Jenkins Git plugin.
recently?
step 7 of
Torben
Ian
On master:
On 2.9.x
Sphinx.
Sphinx.
docs
<http://ares.boundlessgeo.com/jenkins/view/geoserver/job/geoserver-master/2600/consoleFull>
  • cp -r build/html
wrong…
not?
Ing. Andrea Aime
@geowolf
Technical Lead
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New Data
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
luminaries
Ian Turton
Christian Del Pino
DevOps Engineer
Email: cdelpino@anonymised.com…
Ben Caradoc-Davies <ben@anonymised.com…>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Jody Garnett
Hi Ben,
Jody was working on the automated doc build on Friday, I have added him to this email. Looks like it is mostly being resolved in the other thread though.
Torben
On Sun, Jul 24, 2016 at 12:39 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Torben,
Kind regards,
Ben.
conflicting.
Kind regards,
Ben.
Torben,
Kind regards,
Ben.
updated
correctly now.
and
Torben
Director
New Zealand
Thanks ben, providing a distinct work space has resolved the conflict.
On 24 July 2016 at 12:39, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Torben,
Kind regards,
Ben.
conflicting.
Kind regards,
Ben.
Torben,
Kind regards,
Ben.
updated
correctly now.
and
Torben
Director
New Zealand
Jody Garnett
