On Fri, Jul 10, 2015 at 11:14 PM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
Going through the dev guide pull requests, there is commentary that was
not resolved before the work was merged.
Checkout out https://github.com/geoserver/geoserver/pull/1135 shows the
idea of only supporting pull requests (and taking the language about
patches).
I am kind of good with that, the section is awkward to read, and it is
very seldom we get patches attached to a jira ( unless the fix is so small
they just provide it in a comment).
+1 of course, as I'm the one that suggested it
Not sure if others are eager to take on patches instead, there are a few I
could point to in Jira if you are interested
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
