[Geoserver-devel] Tie Hibernate Datastore into Geoserver
We have been trying now for 4 days to try and hook up the hibernate datastore into Geoserver and no luck yet. Can anyone provide some light on this situation. It is really hurting us right now.
Kind Regards
Clint Lewis
We tried,
The first thing we tried to do was just add the jars to lib/ like in 1.3. This no longer possible in 1.4 due to maven + mvn jetty6:run process (do you have link whats actually occurring here?).
Next we tried to add the jars by adding to the classpath in eclipse (see the 1.4 debug run instructions - instead of just adding the maven jar, we also add all ours). This was very strange; we had to also include gt2-main jars (etc) even though they are already used by geoserver. We also had to add the apache logging system (commons-logging), and that caused problems because there were then 2 of them (I assume geoserver also has one) -- the logger started throwing errors.
We've done a large number of other things, and we are pretty much out of ideas. We did get it partially running by adding the files to the web-inf/lib directory for the .exe installer. But, geoserver is not behaving properly and we need to debug why it keeps creating the DS multiple times and keeps throwing errors randomly - we'd like to run it in the debugger!
Kind Regards
Clint Lewis
Clint Lewis wrote:
Hi Brent,
Thanks for the reply, we trying just drop our hibernate data store into geoserver, but there are like 20 jars and under mvn / spring there is now way to say take these jar and getting it work in the debugger. But it works for our test-case, that is the funny thing.
Kind Regards
Clint Lewis
Brent Owens wrote:
Can you tell us more of what steps you have taken?
I don't know much about the hibernate datastore but if it is like the
others you should just be able to build it with geotools and drop the
jar into geoserver. Just like the oracle, mysql datastores.
theoretically
Brent
On 9/14/06, Clint Lewis <louiecw@anonymised.com> wrote:
Kind Regards
Clint Lewis
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Another thing we did was to add a bunch of dependencies in the web/pom.xml in geoserver but then transitive dependencies caused problems cause it need lots of other jars in the poms of there dependencies added. These dependencies have spring beans in then that are unused by geoserver, but geoserver is trying to initialize them.
Kind Regards
Clint Lewis
Clint Lewis wrote:
We tried,
Kind Regards
Clint Lewis
Clint Lewis wrote:
Hi Brent,
Kind Regards
Clint Lewis
theoretically
Brent
Kind Regards
Clint Lewis
Try the following.
1. Build the web module with 'mvn install war:war'
2. Copy your hibernate data store plugin into 'target/geoserver/WEB-INF/lib'
3. Then run with 'jetty:runWar' instead of 'jetty:run'
Let me know if that works.
-Justin
Clint Lewis wrote:
We tried,
in the debugger!
Kind Regards
Clint Lewis
Clint Lewis wrote:
Hi Brent,
Kind Regards
Clint Lewis
theoretically
Brent
Kind Regards
Clint Lewis
security?
job easier
Geronimo
!DSPAM:1004,450930b8147009771116852!
Justin Deoliveira
jdeolive@anonymised.com
The Open Planning Project
http://topp.openplans.org
I tried this but got the following error. We are currently using 1.4.0-M0 and this uses Jetty6 plugin not Jetty so I tried mvn jetty6:runWar and this goal does not exsists.
C:\java\1.4.0-M1\web>mvn jetty:runWar
[INFO] Scanning for projects...
[INFO] Searching repository for plugin with prefix: 'jetty'.
[INFO] artifact org.apache.maven.plugins:maven-jetty-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-jetty-plugin: checking for updates from central
[ERROR] BUILD ERROR
[INFO] The plugin 'org.apache.maven.plugins:maven-jetty-plugin' does not exist or no valid version could be found
[INFO] Total time: 4 seconds
[INFO] Finished at: Thu Sep 14 13:50:53 GMT 2006
[INFO] Final Memory: 4M/7M
C:\java\1.4.0-M1\web>mvn jetty6:runWar
[INFO] Searching repository for plugin with prefix: 'jetty6'.
[ERROR] BUILD FAILURE
[INFO] Required goal not found: jetty6:runWar
[INFO] Total time: 1 second
[INFO] Finished at: Thu Sep 14 13:51:03 GMT 2006
[INFO] Final Memory: 3M/7M
Kind Regards
Clint Lewis
Justin Deoliveira wrote:
Try the following.
-Justin
Clint Lewis wrote:
We tried,
Kind Regards
Clint Lewis
Clint Lewis wrote:
Hi Brent,
Kind Regards
Clint Lewis
theoretically
Brent
Kind Regards
Clint Lewis
Sorry, I spelled it wrong, its mvn jetty:run-war
[INFO]
[ERROR] BUILD ERROR
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Kind Regards
Clint Lewis
Try the following.
-Justin
Clint Lewis wrote:
We tried,
throwing errors.
it in the debugger!
Kind Regards
Clint Lewis
Clint Lewis wrote:
Hi Brent,
Kind Regards
Clint Lewis
theoretically
Brent
light
Kind Regards
Clint Lewis
security?
job easier
Geronimo
security?
job easier
Geronimo
!DSPAM:1004,4509445c152007731818748!
Justin Deoliveira
We figured this out thanks :stuck_out_tongue:
Kind Regards
Clint Lewis
[INFO]
[ERROR] BUILD ERROR
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Kind Regards
Clint Lewis
Try the following.
-Justin
Clint Lewis wrote:
We tried,
throwing errors.
it in the debugger!
Kind Regards
Clint Lewis
Clint Lewis wrote:
Hi Brent,
Kind Regards
Clint Lewis
theoretically
Brent
light
Kind Regards
Clint Lewis
security?
job easier
Geronimo
security?
job easier
Geronimo
