I've just committed the raster part of the wms dimensions work too.
Now I miss documentation and WCS improvements (which I did not foresee
in the proposal, but are necessary as well).
If you want to try time/elevation enabled mosaic there are no docs, but you
can get some pre-made from the gt image mosaic tests here:
http://svn.osgeo.org/geotools/trunk/modules/plugin/imagemosaic/src/test/resources/org/geotools/gce/imagemosaic/test-data/ensmean.zip
http://svn.osgeo.org/geotools/trunk/modules/plugin/imagemosaic/src/test/resources/org/geotools/gce/imagemosaic/test-data/watertemp.zip
http://svn.osgeo.org/geotools/trunk/modules/plugin/imagemosaic/src/test/resources/org/geotools/gce/imagemosaic/test-data/time_geotiff/
By looking at the example you should also be able to build your own:
basically the
mosaic building code expects to find the time and elevation as part of the name
of the file, and uses regular expressions to extract them and place them into
the index shapefile.
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
