We have a client with the following use case. They are serving up time based hurricane data that is constantly being updated. And often the dataset will be completely empty. In that case what they want to show is an empty map. Currently this fails when trying to query the layer without specifying a timestamp ,which defaults to “current”. That causes a query for the max time in the dataset and because there are no features it chokes.
So… how to fix. I can think of a few possibilities.
Force the client to always specify a explicit time. Not ideal for them in this case because they rely on the fact that not specifying a time stamp will return the “current”.
Explicitly handle the empty case and when asking for the “current” time we literally return back the current time at that instant.
Handle it similar to the bounding box case and have users specify some metadata on the DimensionInfo object that specifies the range of the time dimension. Obviously not nice for dynamic data as in this case.
I am sure there are other options as well. Thoughts appreciated.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
On Fri, Jun 22, 2012 at 9:04 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
It chokes how? During the query itself?
It would be nice if we could just get “null” back and handle that by returning an empty image?
Which would result in an empty response too. Wondering though, what if in the request we have two layers with time enabled, one
that has a current value, one that does not?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
On Sat, Jun 23, 2012 at 3:47 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
It throws an exception from WMS.getCurrentTime(). Long story short it uses a MaxVisitor to figure out the max time from the dataset which thows an exception from getMax() since no features are visitied.
Hmmm… right. They would result in different times being queries. But afaik we already have this issue right? Both layers are queried individually for the max time and they could be different?
Ing. Andrea Aime
Tech lead
Justin Deoliveira
On Sun, Jun 24, 2012 at 7:17 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
This sounds like a bug to me. If I run a query in SQL asking for the max of an empt table I just get back a null, this should work the same.
Correct, we’re toast anyways, not sure even what the correct behavior would be:
- if we extract a different “current” for each layer we’d get a representation mixing different times
- if we extract the max of the maxes possibly only one layer would show up
My worry is that grabbing a fixed time we could end up catching some data from other layers that would have not showed
up otherwise (data coming from computerized simulations might refer to the future, so chosing “now” does not mean chosing a value higher
than any other).
Ing. Andrea Aime
Tech lead
On Sun, Jun 24, 2012 at 2:11 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Agreed. I’ll see if about updating the visitor but simply returning null from WMS.getCurrentTime() will just push the problem further down the chain.
than any other).
Right… definitely a complex issue and I don’t thinking the spec is very clear about this afaik? So I don’t imagine i am going to tackle the bigger issue here so the question is is just updating WMS.getCurrentTime() to return the actual current time when no data is available acceptable? Or do we feel an exception as it is now is better behaviour?
Ing. Andrea Aime
Tech lead
Justin Deoliveira
