On Tue, Jan 24, 2017 at 1:28 AM, Dave Blasby <dblasby@anonymised.com>
wrote:
For the get capabilities (layer Time dimension set to LIST and default=max
value) you will see two queries;
1. unique visitor (Postgis: SELECT DISTINCT ...) to get the LIST of values
2. max visitor (Postgis: SELECT max ...) to get the default value
For most datasets (i.e. non-database), this will be 2 full scans of the
dataset.
Hum... that's debatable imho, only dumb datasets are really forced into
full scans.
Shapefile certainly cannot optimize out the visitors, but other data stores
could if code was added to them.
E.g., SOLR and Mongo can both execute max visitor fast, but there is no
optimized implementation in the store.
What's annoying is that there is no way to know if a store can optimize
these operations.
That said, time based data requires a index to operate efficiently (all
request will hit a specific
time or time range) so... well... you definitely don't want to run it off a
shapefile or other
non indexed source. And if there is an index, both those operations should
be easy to optimize
(given developer time).
About static vs dynamic, both have their own use case, what we have today
in GeoServer
is the case that sponsored the original functionality (e.g. data mostly
static from the spatial
p.o.v. and changing quite aggressively on the temporal p.o.v.), full
dynamic bboxes
and cached/configured dimensions values both make sense and their support
could
be created given enough development resources.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
