Dear All,
we would like make a new beta release of GeoServer 2.1 in the very short term.
Objections? Anyone caring to help?
Simone.
Notice that our office phone number has recently changed!
Please, update your records!
Ing. Simone Giannecchini
Founder
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
mob: +39 333 8128928
http://www.linkedin.com/in/simonegiannecchini
http://twitter.com/simogeo
I would be happy to help. And perhaps in return the coverage experts can look into an outstanding issue we have with the wcs 1.1 cite tests. The issue being that they only work if we force geotiff as the only output format, which for that test suite (unlike the wcs 1.0 one) is not settable in the test setup. We more or less have to hack the config files to only allow the one supported output format.
On Thu, Oct 28, 2010 at 9:11 AM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Dear All,
Simone.
Founder
fax: +39 0584962313
Nokia and AT&T present the 2010 Calling All Innovators-North America contest
Create new apps & games for the Nokia N8 for consumers in U.S. and Canada
$10 million total in prizes - $4M cash, 500 devices, nearly $6M in marketing
Develop with Nokia Qt SDK, Web Runtime, or Java and Publish to Ovi Store
http://p.sf.net/sfu/nokia-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
One idea Justin and I kicked around was to make the db-backed catalog the default (using h2), so as to get better testing on it. Not sure if it’s ready for that level of testing, but I think it could be a nice way to make it more solid as a lot more people than normal would test it.
We could do it for the betas, then switch back to the old way for the release candidates and final release.
On Thu, Oct 28, 2010 at 11:25 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Dear All,
Simone.
Founder
fax: +39 0584962313
Justin Deoliveira
Ciao Chris,
I am not _so_ in favour of this idea since it will make the betas
relatively unusable
if you plan to publish many layer, which covers all the use cases that
we have
I am not sure about this but we could prepare separate/accompanying
releases to test the dbconfig.
Simone.
Founder
fax: +39 0584962313
On Thu, Oct 28, 2010 at 5:41 PM, Chris Holmes <cholmes@anonymised.com> wrote:
default (using h2), so as to get better testing on it. Not sure if it's
Dear All,
term.
Simone.
Founder
fax: +39 0584962313
contest
Canada
marketing
Justin Deoliveira
contest
marketing
I don't like this idea, unless we plan to release the final with the H2 catalog
by default (that would require another gsip and so on).
Wouldn't it be possible to make that a plugin so that interested people can
try it out instead and leave betas for what they are meant for, that is,
test what will eventually become the stable.
Testing a community module, even if of great importance, should not be
part of the base release.
But I would be +1 on having the artifact be built, and included in the
announcement so that everyone interested can check it out.
You could also just make it part of the nightly build and blog about it
so that everybody can download nightlies and play with it.
Since you're still heavy developing it it would be the best way to keep
on providing people testing it out with the latest evolutions, check
out bug fixes and so on. No?
Ing. Andrea Aime
Senior Software Engineer
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
