[Geoserver-devel] time to merge spring-4-update
The spring-4-update branch from gwc and geoserver finished up last week, based on today’s meeting (and email geofence discussion) I would like to merge now and begin manual testing.
Andrea asked that I delay the beta2 release until after geofence is ready. Please confirm and I can update the spring 4 upgrade schedule.
Jody Garnett
Merging sooner than later seems like a good plan to me
Ian
On 22 March 2016 at 20:45, Jody Garnett <jody.garnett@anonymised.com…403…> wrote:
Jody Garnett
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785351&iu=/4140
Geoserver-devel mailing list
Ian Turton
I am fine with doing the merge now for starting with tests.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, Mar 22, 2016 at 10:16 PM, Ian Turton <ijturton@anonymised.com> wrote:
Ian
based on today's meeting (and email geofence discussion) I would like to
merge *now* and begin manual testing.
Jody Garnett
Ian Turton
Thanks Ian / Simone - I know it is “going according to plan” but I did not want to disrupt without notice.
Niels I noticed a pull request 1540 which has some security refactoring, this will probably need to be redone after the merge.
On 23 March 2016 at 02:40, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
Ian
Jody Garnett
Ian Turton
Jody Garnett
GWC update is merged.
Kevin Michael Smith
smithkm@anonymised.com
Jody Garnett
On 23 March 2016 at 02:40, Simone Giannecchini <simone.giannecchini@anonymised.com…1268…> wrote:
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Ian
Jody Garnett
Ian Turton
Thanks, Jody. I see you have just merged the Spring 4 branch on master. Jenkins on ares is running.
http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2330/
I am also running a local build with OpenJDK 8.
The only way out is through!
Kind regards,
Ben.
<https://github.com/geoserver/geoserver/wiki/Spring-4-Upgrade&gt; schedule.
Jody Garnett
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
You caught me before the build was done … here is the good news:
[INFO] BUILD SUCCESS
[INFO] Total time: 28:43.639s
Next up testing, please keep score on the wiki -
In the interest of not filling up jira with noise please start with an email to the list.
Kind regards,
Ben.
<https://github.com/geoserver/geoserver/wiki/Spring-4-Upgrade> schedule.
Jody Garnett
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Jody Garnett
Jenkins on ares passed as did my local build and an app-schema-online test against postgis (the latter is still running on ares).
I have kicked the nightly build on ares Jenkins to see if community modules compile and assembly succeeds. I have also kicked cite tests.
I am also compiling community modules locally (-DskipTests build) and will likewise test assembly.
I will not switch Maven to 3.3.9 on ares Jenkins until the dust settles. :slight_smile:
Kind regards,
Ben.
Kind regards,
Ben.
Jody Garnett
Director
New Zealand
Local compile and assembly (and community assembly) all passed.
[WARNING] The POM for no.ecc.vectortile:java-vector-tile:jar:1.0.5 is missing, no dependency information available
I think this is the same missing dependency Andrea reported in the 2.8.3 release.
Director
New Zealand
email to the list.
Jody, does this request still hold? Should we be adding notes on the Spring 4 Upgrade wiki page or collating bugs on a new page? Or should we start using Jira? (I concur with your view that it is a bit early for Jira.):
If we leave that page for schedule and work assignment, we could have another page for a laundry list of known issues.
A buglet:
Login fails from the layer preview page (in Jetty from Eclipse). I am pretty sure that this failed *before* the Spring 4 upgrade but I am sure that we want to fix this while fixing all the /login and /logout endpoints for Spring 4 compatibility:
HTTP ERROR 404
Problem accessing /geoserver/web/wicket/j_spring_security_check. Reason:
     Not Found
Powered by Jetty://
Kind regards,
Director
New Zealand
email to the list.
Yeah.
Let me try using the same wiki page (using the headings we have or adding
new headings to group issues).
A buglet:
HTTP ERROR 404
    Not Found
Powered by Jetty://
Kind regards,
I added your buglet, the page is pretty busy, if we break out a new page
it would have to be for manual testing, and issues (since separating the
two seems madness).
Okay here is what I am going to do, send an email for each buglet, and link
to the email thread from the wiki page - that way we get the discussion and
a list so we know when we are done.
What we really want is the discussion for fixing and sharing which approach
to a fix was successful. For this to work we will need to try for an email
thread per buglet.
