I have been working on GEOT-2903 [1], taking into account all the
feedback received so far.
The most important points are:
a) the functionality is now enabled with a profile:
"org.geotools.shapefile.datetime", and
b) compatibility (read/write) has been verified with a software
called DBF Viewer 2000.
More information, sample files, screenshots can be found attached to
the JIRA in [1].
Thanks in advance for any feedback you can provide.
GeoTools is going through an IP review and we got a question about the reference to DBF Viewer 2000 you describe in GEOT-2903 (and in this email thread).
//(43200000L: 12 hour correction factor taken from DBFViewer2000)
Can I ask if you found that constant in the DBF Viewer 2000 source code, or were just using DBF Viewer 2000 for testing and determined the value from documentation or experimentally.
“org.geotools.shapefile.datetime”, and
the JIRA in [1].
Throughout its 18-year history, RSA Conference consistently attracts the
world’s best and brightest in the field, creating opportunities for Conference
attendees to learn about information security’s most important issues through
interactions with peers, luminaries and emerging and established companies. http://p.sf.net/sfu/rsaconf-dev2dev
