Jody,
I have installed eclipse 2.1.2 as my development platform. I have not used struts before, so i thought it might be helpful to install easystruts, as a quick way to start into struts development. I have installed the plugin, but when i try to "Add Easystruts Support", i do not know what i should fill out in the wizard. I guess I need to only change the "Base package for generation", and "Default application resource" fields. But when i try to change these to something like org.vfny.geoserver, then i get an error at the top of the wizard which is hidden from view. I cannot see what the error is. I'm guessing that you use eclipse, and easystruts, as i saw your name in a forum concerning easystruts and eclipse. do you have any suggestions?
Jamie
----Original Message Follows----
To: Jody Garnett <jgarnett@anonymised.com>
CC: "ROLDAN, Gabriel raul" <gabriel.raul.roldan@anonymised.com>,'Jamie Eyre' <jweyre@anonymised.com>,geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Tomcat and JSPCompiler
Date: Wed, 10 Mar 2004 15:35:58 -0800
Downloaded a fresh version of Tomcat and things have started working again,
Thanks for the help Gabriel
Jody Garnett wrote:
I tried the change you suggested, in the hopes of a quick fix. It did work on Resin 2.X, I could not get Tomcat to work for me at all, and Resin 3.X resulted in the following error:
WEB-INF/web.xml:140: `JSPCompiler' is an unknown servlet-name. servlet-mapping
requires that the named servlet be defined in a <servlet> configuration
before the <servlet-mapping>.
Not sure where this leaves us for making a release - ideas? And what version of Tomcat are you using? I think I am using Tomcat 5.X.
Jody,
Easy Struts will not be any use, as we use more complex operations ... I used Oreily's "Jakarta Struts" ... can probably go to the jakarta website for everything you would need.
David
Jamie
This SF.Net email is sponsored by: IBM Linux Tutorials
Free Linux tutorial presented by Daniel Robbins, President and CEO of
GenToo technologies. Learn everything from fundamentals to system
administration.http://ads.osdn.com/?ad_id=1470&alloc_id=3638&op=click
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Jody,
I had to give up on easystruts since I was using Eclipse3.0 M7 - I have been playing with various files by hand. Eclipse 3.0 is required in order to play nice with Source Forge.
In the developers docs there is a file that walks through the process required to update the configuration files to allow for a new option. It includes a section on adding the new option to struts. Probably the best place to start.
Note that the website developer docs have fallen behind a little bit.
The file is:
documents/developer/howToConfig.xml
Ant can be used to turn these files into readable html.
