[Geoserver-devel] Towards nicer looking URLs in the UI
today I've been working out a patch for
http://jira.codehaus.org/browse/GEOS-3401
The patch tries hard to remove all inter-page ajax links and
replace them with bookmarkable ones, resulting in links that
survive a sessions timeout, a server restart, and that can
be bookmarked.
The patch itself is not small, so if anyone wants to give it
a look, it would be appreciated.
Once that is in we have to find a way to get something better looking
than:
http://localhost:8080/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.wms.web.data.StyleEditPage&name=pophatch
We already discussed this in the past:
http://old.nabble.com/Nice-URLs-in-Wicket-to18128232.html#a18128232
http://old.nabble.com/Clean-up-Wicket-URLs%2C-part-two-td24427423.html
The final solution was the idea of registering something in the
Spring context that would make the page be mounted following
certain contentions.
Just today I stumbled into these annotations that would basically
allow us to specify the mount point in the class itself:
http://wicketstuff.org/confluence/display/STUFFWIKI/wicketstuff-annotation
On one side it seems handier than declaring the mount path in
xml. On the other side, we'd start to have two sources for page
information, the spring files for menu entries, and the annotations
for the rest.
And oh, the above annotations would make us write the mount point
explicitly instead of following a convention (but I guess if we
really wanted we could roll our own annotations with no
parameters, something like @MountPage)
What do you think? What is the best path forward?
Andrea Aime
OpenGeo - http://opengeo.org
I did not review the patch in too much detail but it looks sensible given the bug report.
One thing though is that it seems this introduces a right way and a wrong way to do linking between pages. It might be good to have this summarized somewhere for wicket novices such as myself.
Andrea Aime wrote:
be bookmarked.
than:
for the rest.
Justin Deoliveira
