For the geosync project, we need to create an rss feed which contains the wfs:Transaction objects which get executed against a particular feature type.
This should be pretty straight forward, as a first shot we intend to simply register a transaction listener, and then serialize the "Events" into an rss feed.
It would be incredibly convenient for us if the transaction event contained the original transaction object, one of:
Justin this is the same as the feature event model; did you want to combine forces and only debug this once?
You will also find you are missing some information I think you need - namely the generated feature ids.
Do you get my earlier feedback about the geosync project? I don't want to repeat myself if it was not useful the first time.
Jody
I dont understand, how are they related? The transaction listener api i am talking about is geoserver only, not geotools.
Jody
Yes, but the geosync stuff we are doing now is *very* prototype. We are pretty much doing the minimum to participate in the ows-5 testbed, and see what it fleshes out. Based on that we can go back and do it "properly".
We have the same needs for the events that go out when a commit() and rollback() go out...
Jody
Fair enough; I was just worried that FeatureId was being ignored in the mix But if it is just play time have fun...
Jody
