Hello !!
I thaught all my geoserver problems were solved, but that was false
I only have a problem during "Insert" transactions.
Just have a look at this xml response :
<wfs:TransactionResponse
version="1.0.0"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs ../wfs/1.0.0/WFS-transaction.xsd">
<wfs:TransactionResult>
<wfs:Status>
<wfs:FAILED/>
</wfs:Status>
<wfs:Message>null: Problem updating features: org.geotools.data.DataSourceException: Some sort of database connection error: ERROR: current transaction is aborted, queries ignored until end of transaction block
cause: java.sql.SQLException: ERROR: current transaction is aborted, queries ignored until end of transaction block
</wfs:Message>
</wfs:TransactionResult>
</wfs:TransactionResponse>
My transaction request looks like this :
<?xml version="1.0"?>
<wfs:Transaction version="1.0.0" service="WFS"
xmlns="http://www.openplans.org/myns"
xmlns:gml="http://www.opengis.net/gml">
<wfs:Insert>
<commune>
<gid>1000</gid>
<ID_BDCARTO>15</ID_BDCARTO>
<NOM_COMM>CHewBIzz</NOM_COMM>
<INSEE_COMM>007</INSEE_COMM>
<STATUT>Capitale</STATUT>
<X_COMMUNE>668000</X_COMMUNE>
<Y_COMMUNE>1802360</Y_COMMUNE>
<SUPERFICIE>5000</SUPERFICIE>
<POPULATION>5000</POPULATION>
<INSEE_CANT>14</INSEE_CANT>
<INSEE_ARR>3</INSEE_ARR>
<NOM_DEPT>AUDE</NOM_DEPT>
<INSEE_DEPT>11</INSEE_DEPT>
<NOM_REGION>LANGUEDOC-ROUSSILLON</NOM_REGION>
<INSEE_REG>91</INSEE_REG>
<the_geom>
<gml:Polygon>
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates>-100,50 -110,55 -100,60 -50,55 -100,50</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</the_geom>
</commune>
</wfs:Insert>
</wfs:Transaction>
I attached the complete log file of my resin server (i found how to get it :] )
In this file, the last thing geoserver does before failling is launching the following query :
SELECT oid, gid, id_bdcarto, nom_comm, insee_comm, statut, x_commune, y_commune, superficie, population, insee_cant, insee_arr, nom_dept, insee_dept, nom_region, insee_reg, AsText(the_geom) FROM commune LIMIT 100000;
So i tried this query on my PostGIS Database, and it worked well.
That's why i can't find where the problem is !
If someone could help, I would really appreciate.
(Note that I run geoserver on Windows, with a remote PostgreSQL/PostGIS database on Solaris 8, maybe this can help ... And sorry for the bad english too)
Thanks !
Steph W.
_________________________________________________________________
MSN Messenger : dialoguez en direct avec vos amis ! http://www.msn.fr/msger/default.asp
(attachments)
stdout-log.txt (18.6 KB)
