[Geoserver-devel] Transactions: inserts
I cannot get inserts working. The features I receive on the server side
do not have any attributes. The attributes are somehow dropped along the
xml filter chain. It is (most likely) not a data source related problem.
I believe the source of problems lies in TransactionFeatureHandler.
Any ideas what might cause this problem? Otherwise I will start to debug
the filter chain step by step and see where the attributes are dropped
(the received xml seems to be ok).
An example of what I receive on server side:
<?xml version="1.0" encoding="utf-16"?>
<wfs:Transaction version="1.0.0" service="WFS"
xmlns:wfs="http://www.opengis.net/wfs&quot;&gt;
  <wfs:Insert handle="insert gps point">
    <RQS_POINT xmlns="http://www.someserver.com/myns&quot;&gt;
      <GEOM>
        <Point xmlns="http://www.opengis.net/gml&quot;&gt;
          <coord>
            <X>202238.869</X>
            <Y>604600.558</Y>
            <Z>578.672</Z>
          </coord>
        </Point>
      </GEOM>
    </RQS_POINT>
  </wfs:Insert>
</wfs:Transaction>
Another question: are optional attributes supported by the
TransactionFeatureHandler? The above feature type could have some more
attributes but they are all optional (in short: the FeatureType has a
corresponding attribute for them, but the created feature does not).
Does this cause any problems? I think I've glimpsed some potential
problem areas, that's why I ask.
Simon
Ok, I think I've solved this problem. I believe a bug was introduced that
broke readCoords when some better handling of coordinate buffers was
added. I fixed it in geotools cvs, and updated the jars in geoserver cvs
on head and wms-merge.
Looking at the code, I think the Z coord should work with Oracle. It does
not work with Postgis at this time however, as it communicates with Well
Known Text (or Binary), and the well known stuff is fuzzy on the z
coordinate, so JTS just doesn't use it in its WKT reader/writer. When we
move to WKB4J it may be easier to support, it looks like it deals with 3d
stuff a bit better.
Chris
      <GEOM>
          <coord>
            <X>202238.869</X>
            <Y>604600.558</Y>
            <Z>578.672</Z>
          </coord>
        </Point>
      </GEOM>
    </RQS_POINT>
  </wfs:Insert>
</wfs:Transaction>
Simon
This SF.net email is sponsored by: SF.net Giveback Program.
Does SourceForge.net help you be more productive? Does it
help you create better code? SHARE THE LOVE, and help us help
YOU! Click Here: http://sourceforge.net/donate/
Geoserver-devel mailing list
that
cvs
Well, the coordinate reading does work now, but I get an exception from
the server now:
"Logisches Handle nicht mehr gültig" means something like "logical
handle no longer valid"
org.vfny.geoserver.responses.WfsTransactionException:
org.vfny.geoserver.responses.WfsTransactionException: Problem updating
features
: org.geotools.data.DataSourceException: Geometry Conversion error when
adding features: java.sql.SQLException: Logisches Handle nich
t mehr gültig cause: oracle.sdoapi.geom.InvalidGeometryException:
java.sql.SQLException: Logisches Handle nicht mehr gültig
        at
org.vfny.geoserver.responses.TransactionResponse.getSub(TransactionRespo
nse.java:212)
        at
org.vfny.geoserver.responses.TransactionResponse.getXmlResponse(Transact
ionResponse.java:105)
        at
org.vfny.geoserver.servlets.Transaction.doPost(Transaction.java:65)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
        at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Applica
tionFilterChain.java:247)
        at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilt
erChain.java:193)
        at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValv
e.java:256)
        at
org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.i
nvokeNext(StandardPipeline.java:643)
        at
org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:4
80)
        at
org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:995)
        at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValv
e.java:191)
        at
        at
80)
        at
        at
org.apache.catalina.core.StandardContext.invoke(StandardContext.java:241
7)
        at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java
:180)
        at
        at
org.apache.catalina.valves.ErrorDispatcherValve.invoke(ErrorDispatcherVa
lve.java:171)
        at
nvokeNext(StandardPipeline.java:641)
        at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java
:172)
        at
        at
80)
        at
        at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.
java:174)
        at
        at
80)
        at
        at
org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapter.java:193)
        at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:78
1)
        at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processC
onnection(Http11Protocol.java:549)
        at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:58
9)
        at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool
.java:666)
        at java.lang.Thread.run(Thread.java:534)
Caused by: org.vfny.geoserver.responses.WfsTransactionException: Problem
updating features: org.geotools.data.DataSourceException: Ge
ometry Conversion error when adding features: java.sql.SQLException:
Logisches Handle nicht mehr gültig cause: oracle.sdoapi.geom.Inv
alidGeometryException: java.sql.SQLException: Logisches Handle nicht
mehr gültig
        at
org.vfny.geoserver.responses.TransactionResponse.doInsert(TransactionRes
ponse.java:252)
        at
nse.java:195)
        ... 33 more
does
Well
we
3d
stuff a bit better.
Chris
side
the
problem.
debug
dropped
> <GEOM>
> <coord>
> <X>202238.869</X>
> <Y>604600.558</Y>
> <Z>578.672</Z>
> </coord>
> </Point>
> </GEOM>
> </RQS_POINT>
> </wfs:Insert>
> </wfs:Transaction>
more
a
> Simon
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
