I’m getting a TransformerException, below, when making a GetFeature request for a complex feature layer. The GeoServer configuration claims to be version 1.3.0.
The features are created from a single Oracle table, but are grouped to provide a single ‘site’ with multiple 'result’s.
I get proper and expected responses to my GetFeature requests when multiple sites are returned, or when a single site is created from multiple database records. When a single site with a single record is requested, I get the exception.
I do not have the option of upgrading GeoServer at the moment. Is this a know issue in this version, and are there workarounds?
Mark Leslie
<?xml version="1.0" ?>
<ServiceExceptionReport
version="1.2.0"
xmlns="[http://www.opengis.net/ogc](http://www.opengis.net/ogc)"
xmlns:xsi="[http://www.w3.org/2001/XMLSchema-instance](http://www.w3.org/2001/XMLSchema-instance)"
xsi:schemaLocation="[http://www.opengis.net/ogc](http://www.opengis.net/ogc) [http://wfs.test.dnr.nsw.gov.au:80/geoserver/schemas//wfs/1.0.0/OGC-exception.xsd](http://wfs.test.dnr.nsw.gov.au:80/geoserver/schemas//wfs/1.0.0/OGC-exception.xsd)">
<ServiceException>
javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:122)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:97)
at org.vfny.geoserver.wfs.responses.GML2FeatureResponseDelegate.encode(GML2FeatureResponseDelegate.java:236)
at org.vfny.geoserver.wfs.responses.FeatureResponse.writeTo(FeatureResponse.java:130)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:510)
at org.vfny.geoserver.servlets.AbstractService.doPost(AbstractService.java:387)
at org.vfny.geoserver.servlets.AbstractService.doPost(AbstractService.java:293)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:199)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:282)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:754)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:684)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:876)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:595)
Caused by: java.lang.RuntimeException: Error reading Features
at org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.handleFeatureReader(FeatureTransformer.java:395)
at org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.encode(FeatureTransformer.java:359)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:603)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:463)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:285)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:118)
... 26 more
Caused by: java.util.NoSuchElementException: No such Feature exists
at org.geotools.data.MaxFeatureReader.next(MaxFeatureReader.java:57)
at org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.handleFeatureReader(FeatureTransformer.java:376)
... 31 more
... 31 more
</ServiceException>
</ServiceExceptionReport>
