[Geoserver-devel] Translating GeoServer 2.0 UI
Hola, me perdí unos días. Hace un par de semanas que vengo renegando con Jinja2-2.1.1-tar.gz No he podido instalarlo. Me tira un error en la compilación. Estoy investigando la solución.
Si se puede facilitar en envió del material traducido seria un golazo. Porque hasta ahora no he podido enviar nada del material ya traducido por no poder instalar las herramientas.
Saludos
Hi, I missed a few days. A couple of weeks I have some time reneging with Jinja2-2.1.1-tar.gz I could not install it. I throws an error in the compilation. I’m investigating the solution
If it is possible to be facilitated sending the material translated, would a “home run”… Because until now I could not send anything in the translated material for not being able to install the tools.
Greetings
www.nramire1.unlugar.com
Encontra las mejores recetas con Yahoo! Cocina.
http://ar.mujer.yahoo.com/cocina/
I could provide a linux-based virtual machine image ready to go with
subversion, the sphinx build tool, and a text editor. If this sounds
useful to you (given bandwidth considerations, etc.) let me know.
-d
Saludos
the compilation. I'm investigating the solution
would a “home run”.. Because until now I could not send anything in
Greetings
______________________________________________________________________
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
_______________________________________________ Geoserver-devel mailing list Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Sería estupendo simplificar la instalación de las herramientas necesarias. Ya que estoy parado por este problema. El ancho de banda no seria un problema, al menos de mi parte.
It would be nice to simplify the installation of the necessary tools. I am stopped by this problem. The bandwidth would not be a problem, at least on my part.
— El jue 20-ago-09, David Winslow dwinslow@anonymised.com escribió:
> De: David Winslow dwinslow@anonymised.com
> Asunto: Re: [Geoserver-devel] Translating GeoServer 2…0 UI
> Para: “nramire1” nramire1@anonymised.com
> Cc: geoserver-devel@lists.sourceforge.net
> Fecha: jueves, 20 de agosto de 2009, 11:22 am
> -d
> > Saludos
> > Greetings
Hi Leandro,
note this thread was more about the translation of the GeoServer user interface itself, not the translation of the user and/or developer documentation, which is sphinx, and what I think is where you´re stuck?
I'm sorry I never installed the sphinx tools on Windows, only on GNU/Linux and Mac OS and its pretty straightforward there. Anyone on the list installed on Windows and can help Leandro figure out what's going on?
Best regards,
Gabriel
www.nramire1.unlugar.com <http://www.nramire1.unlugar.com/&gt;
--- El *jue 20-ago-09, David Winslow /<dwinslow@anonymised.com>/* escribió:
    De: David Winslow <dwinslow@anonymised.com>
    Asunto: Re: [Geoserver-devel] Translating GeoServer 2..0 UI
    Para: "nramire1" <nramire1@anonymised.com>
    -d
     > Hola, me perdí unos días. Hace un par de semanas que vengo renegando
     > con Jinja2-2.1.1-tar.gz No he podido instalarlo. Me tira un error en
     > la compilación. Estoy investigando la solución.
     > Si se puede facilitar en envió del material traducido seria un
    golazo.
     > Porque hasta ahora no he podido enviar nada del material ya traducido
     > por no poder instalar las herramientas.
     > Saludos
     > Hi, I missed a few days. A couple of weeks I have some time reneging
     > with Jinja2-2.1.1-tar.gz I could not install it. I throws an error in
     > the compilation. I'm investigating the solution
     > If it is possible to be facilitated sending the material translated,
     > would a “home run”.. Because until now I could not send anything in
     > the translated material for not being able to install the tools.
     > Greetings
     > www.nramire1.unlugar.com
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day trial. Simplify your report design, integration and deployment - and focus on what you do best, core application coding. Discover what's new with Crystal Reports now. http://p.sf.net/sfu/bobj-july
Gabriel Roldan
OpenGeo - http://opengeo.org
