I just submitted a patch that adds documentation about translating the GeoServer UI to the Developer Manual. Comments/suggestions would be appreciated, especially because I'm going solely on secondhand information.
Also thanks to Oscar F. for the feedback.
http://jira.codehaus.org/browse/GEOS-4323
Mike Pumphrey
OpenGeo - http://opengeo.org
Mike,
Good to see you added hints for translating documentation too.
There are also translation files for some extensions and community modules:
src/extension/arcsde/src/main/java/
src/extension/geosearch/src/main/java/
src/extension/h2/src/main/java/
src/extension/wps/web-wps/src/main/java/
src/community/css/src/main/resources/
src/community/dds/src/main/java/
src/community/hello_web/src/main/java/
src/community/importer/src/main/java/
src/community/inspire/src/main/resources/
src/community/istyler/src/main/resources/
src/community/monitoring/src/main/resources/
src/community/printing/src/main/java/
src/community/proxy/src/main/java/
src/community/python/src/main/java/
src/community/scriptlet/src/main/java/
src/community/translator/src/main/java/
This list doesn't cover all extensions and probably is going to change
often, so we could just add a comment that if someone wants to
translate an extension, searches for 'GeoServerApplication.properties'
file to check if the module is prepared for i18n.
Oscar.
2011/1/21 Mike Pumphrey <mike@anonymised.com>:
Mike Pumphrey
Special Offer-- Download ArcSight Logger for FREE (a $49 USD value)!
Finally, a world-class log management solution at an even better price-free!
Download using promo code Free_Logger_4_Dev2Dev. Offer expires
February 28th, so secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsight-sfd2d
Geoserver-devel mailing list
