Wondering if we have any chance to test Jim’s suggestions.
On Fri, Jul 7, 2017 at 6:31 PM, Jim Hughes <jnh5y@anonymised.com12…> wrote:
Repo issues aside, for GeoMesa, we were seeing slow builds on Travis. One thing which sped things up a little bit was to use the experimental newer Ubuntu version with lines like this in .travis.yml:
sudo: required
dist: trusty
That might help with the actual compile/test speeds…
Jim
On 07/07/2017 12:24 PM, Torben Barsballe wrote:
I’ve had the same issue, and I’ve been seeing this happen more frequently recently.
Torben
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
Geoserver-devel mailing list
[Geoserver-devel@anonymised.com366...sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Geoserver-devel@anonymised.com.366…sourceforge.net
On Fri, Jul 7, 2017 at 9:08 AM, Daniele Romagnoli <daniele.romagnoli@anonymised.comsolutions.it> wrote:
btw, yesterday I had to restart a travis build a couple of time due to the job exceeding timeout
Geoserver-devel@anonymised.comrge.net
On Tue, Jul 4, 2017 at 10:14 AM, Nuno Oliveira <nuno.oliveira@anonymised.comt> wrote:
It may be, well Travis seems to be happy again
On 07/04/2017 08:55 AM, Andrea Aime wrote:
I have seen builds fail due to the maven repository being very slow to respond.
And then, out of the blue some times later, it becomes fast again and builds go.
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
On Mon, Jul 3, 2017 at 10:35 PM, Nuno Oliveira <nuno.oliveira@anonymised.comt> wrote:
Help after trying several times the build just start passing again.
I still have no idea what happen.
On 07/03/2017 01:43 PM, Nuno Oliveira wrote:
I made a change on this PR https://github.com/geoserver/geoserver/pull/2450 fixing a comment typo
and since then the Travis build keeps failing: https://api.travis-ci.org/jobs/249523821/log.txt?deansi=true
It seems that Travis is crashing because of some timeout:
uploading archive
running casher push
took longer than 180 seconds and has been aborted
I’m not sure what is going on, did anyone already experience something similar ?
Nuno Oliveira
@nmcoliveira
Software Engineer
Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
Daniele Romagnoli
