Jody, I don’t follow, the maven-metadata you’re linking does not have a build number.
Imho we should just stop this single centralized maven repo approach, it’s made us waste
a lot of time already and has broken builds for months now, and go back to having
separate repositories…
On Thu, Mar 17, 2016 at 6:27 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
When we got tripped up before it was due to the build number in the maven-metadata.xml - when it was “lower” then the one held locally it did not correctly work.
it.geosolutions.imageio-ext
libjpeg-turbo
1.1.2
1.1.2
1.1-SNAPSHOT
1.1.3
1.1.5
1.1.4
20121030141655
libjpeg-turbo
1.1.2
1.1.2
1.1-SNAPSHOT
1.1.3
1.1.5
1.1.4
20121030141655
Jody Garnett
On 17 March 2016 at 06:11, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Mmm…
it seems it’s still using the old one
https://s3.amazonaws.com/archive.travis-ci.org/jobs/116413208/log.txt
https://s3.amazonaws.com/archive.travis-ci.org/jobs/116201289/log.txt
https://s3.amazonaws.com/archive.travis-ci.org/jobs/116413119/log.txt
Daniele
On Wed, Mar 16, 2016 at 4:44 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140
Geoserver-devel mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
On Tue, Mar 15, 2016 at 11:36 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
So I fixed the original repository, and then did the above, but it does not seem like it’s actually
You can always login and “refresh” the entry in the boundless one.
However in the tag the parent is correct, looks like a deploy issue:
https://github.com/geosolutions-it/imageio-ext/blob/1.1.13/library/libjpegturbo/pom.xml
Wondering, will a manual redeploy on the geosolutions repository also fix the boundless
one?
refreshing the cache, it’s just refreshing the UI to match the contents of the artifactory server side.
The file is still the same…
Just re-kicked a build that previously failed due to the libjpegwrapper issue (and that one only):
https://travis-ci.org/geoserver/geoserver/builds/116201288
We’ll see if artifactory chooses to check the source repo when Travis asks for the pom file
again… or not
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
