[Geoserver-devel] Travis CI build failure on hazelcast
Folks,
I cannot complete a PR because Travis reports an error that does not seem relate to my branch (GEOS-8933):
[INFO] BUILD FAILURE
[INFO] Total time: 25:42 min (Wall Clock)
[INFO] Finished at: 2018-09-24T00:10:06Z
[INFO] Final Memory: 91M/326M
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-restconfig: Found 1 non-complying files, failing build -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wps-cluster-hazelcast: Compilation failure
[ERROR] error: error reading /home/travis/.m2/repository/com/hazelcast/hazelcast/3.3.1/hazelcast-3.3.1.jar; /home/travis/.m2/repository/com/hazelcast/hazelcast/3.3.1/hazelcast-3.3.1.jar (Permission denied)
Could someone look into it?
Luca Morandini
Data Architect - AURIN project
Melbourne eResearch Group
School of Computing and Information Systems
University of Melbourne
Room 255.02, Level 2, 333 Exhibition St.
Melbourne, 3000 VIC
Skype: lmorandini
LinkedIn: https://www.linkedin.com/in/lmorandini
Luca,
Please understand that the GeoServer project does not control the Travis
infrastructure.
I have restarted the build, but if that doesn't help, you can also
"resubmit" the CI build by closing and re-opening the PR.
Brad
-----Original Message-----
Sent: Monday, 24 September 2018 10:23 AM
To: geoserver-devel@lists.sourceforge.net
Subject: [Geoserver-devel] Travis CI build failure on hazelcast
Folks,
[INFO]
[INFO] Total time: 25:42 min (Wall Clock) [INFO] Finished at:
2018-09-24T00:10:06Z [INFO] Final Memory: 91M/326M [INFO]
build -> [Help 1] [ERROR] Failed to execute goal
r;
r
(Permission denied)
Luca Morandini
School of Computing and Information Systems University of Melbourne Room
Melbourne, 3000 VIC
Skype: lmorandini
Geoserver-devel mailing list
On 24/09/18 12:10, bradh@anonymised.com wrote:
Luca,
infrastructure.
What I did is to "touch" a file an re-commit, hence triggering a build, but to no avail.
Shall I try until it succeeds, or can something be done to fix the build on the 2.14.x branch? (I do not think it is related to my commits.)
Luca Morandini
Melbourne, 3000 VIC
Skype: lmorandini
Luca,
infrastructure.
Thanks Brad for restarting it on a different VM. Alas, the build failed with the same error.
Luca Morandini
Melbourne, 3000 VIC
Skype: lmorandini
