On 16/07/17 15:58, Ben Caradoc-Davies wrote:
To avoid timeouts, I changed Travis CI to use -T1C, expecting about four threads. Instead, Maven reports:
"Using the MultiThreadedBuilder implementation with a thread count of 32"
Yes, not two, but 32 threads, despite the documented 2 cores:
https://docs.travis-ci.com/user/ci-environment/
This might cause worker VM memory exhaustion, as each thread can get its own test JVM, and workers are documented to have only 4 GB of memory.
I will see if -T2 yields better results.
Setting -T2 fixed a failing geoserver build. I am trying -T4 to see if it is faster.
Whatever is used in the containerised environment to restrict resource usage, it is not exposed via the usual operating system interface and so -T1C causes 32 threads and risks breaching memory limits (if enough modules are built and tested concurrently; this is a race condition). The documented limit is 2 CPUs and 4 GB of memory.
Output of "free" shows vast memory resources that I guess we do not get to use:
total used free shared buffers cached
Mem: 61829552 25484244 36345308 53500 34680 3863920
-/+ buffers/cache: 21585644 40243908
Swap: 0 0 0
The containerised environment reports 32 "CPUs". Looks like dual E5-2680 each with 8 cores / 16 threads.
Output of "cat /proc/cpuinfo":
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 62
model name : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
cache size : 25600 KB
physical id : 0
siblings : 16
core id : 0
cpu cores : 8
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx rdtscp lm constant_tsc rep_good nopl xtopology eagerfpu pni pclmulqdq ssse3 cx16 pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm fsgsbase smep erms xsaveopt
bugs :
bogomips : 5600.20
clflush size : 64
cache_alignment : 64
address sizes : 46 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 1
cpu cores : 8
apicid : 2
initial apicid : 2
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5675.50
clflush size : 64
power management:
processor : 2
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 2
cpu cores : 8
apicid : 4
initial apicid : 4
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5675.60
clflush size : 64
power management:
processor : 3
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 3
cpu cores : 8
apicid : 6
initial apicid : 6
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5675.44
clflush size : 64
power management:
processor : 4
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 4
cpu cores : 8
apicid : 8
initial apicid : 8
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5675.78
clflush size : 64
power management:
processor : 5
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 5
cpu cores : 8
apicid : 10
initial apicid : 10
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5675.67
clflush size : 64
power management:
processor : 6
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 6
cpu cores : 8
apicid : 12
initial apicid : 12
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5675.52
clflush size : 64
power management:
processor : 7
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 7
cpu cores : 8
apicid : 14
initial apicid : 14
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5675.87
clflush size : 64
power management:
processor : 8
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 0
cpu cores : 8
apicid : 32
initial apicid : 32
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5676.04
clflush size : 64
power management:
processor : 9
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 1
cpu cores : 8
apicid : 34
initial apicid : 34
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5676.21
clflush size : 64
power management:
processor : 10
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 2
cpu cores : 8
apicid : 36
initial apicid : 36
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5676.32
clflush size : 64
power management:
processor : 11
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 3
cpu cores : 8
apicid : 38
initial apicid : 38
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5676.12
clflush size : 64
power management:
processor : 12
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 4
cpu cores : 8
apicid : 40
initial apicid : 40
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5676.50
clflush size : 64
power management:
processor : 13
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 5
cpu cores : 8
apicid : 42
initial apicid : 42
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5676.80
clflush size : 64
power management:
processor : 14
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 6
cpu cores : 8
apicid : 44
initial apicid : 44
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5676.70
clflush size : 64
power management:
processor : 15
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 7
cpu cores : 8
apicid : 46
initial apicid : 46
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5676.55
clflush size : 64
power management:
processor : 16
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 0
cpu cores : 8
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5677.78
clflush size : 64
power management:
processor : 17
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 1
cpu cores : 8
apicid : 3
initial apicid : 3
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5678.13
clflush size : 64
power management:
processor : 18
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 2
cpu cores : 8
apicid : 5
initial apicid : 5
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5677.87
clflush size : 64
power management:
processor : 19
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 3
cpu cores : 8
apicid : 7
initial apicid : 7
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5678.09
clflush size : 64
power management:
processor : 20
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 4
cpu cores : 8
apicid : 9
initial apicid : 9
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5678.04
clflush size : 64
power management:
processor : 21
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 5
cpu cores : 8
apicid : 11
initial apicid : 11
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5678.19
clflush size : 64
power management:
processor : 22
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 6
cpu cores : 8
apicid : 13
initial apicid : 13
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5677.77
clflush size : 64
power management:
processor : 23
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 0
siblings : 16
core id : 7
cpu cores : 8
apicid : 15
initial apicid : 15
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5678.33
clflush size : 64
power management:
processor : 24
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 0
cpu cores : 8
apicid : 33
initial apicid : 33
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5678.41
clflush size : 64
power management:
processor : 25
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 1
cpu cores : 8
apicid : 35
initial apicid : 35
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5677.98
clflush size : 64
power management:
processor : 26
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 2
cpu cores : 8
apicid : 37
initial apicid : 37
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5678.01
clflush size : 64
power management:
processor : 27
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 3
cpu cores : 8
apicid : 39
initial apicid : 39
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5678.02
clflush size : 64
power management:
processor : 28
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 4
cpu cores : 8
apicid : 41
initial apicid : 41
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5678.10
clflush size : 64
power management:
processor : 29
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 5
cpu cores : 8
apicid : 43
initial apicid : 43
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5678.31
clflush size : 64
power management:
processor : 30
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 6
cpu cores : 8
apicid : 45
initial apicid : 45
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5677.98
clflush size : 64
power management:
processor : 31
cpu family : 6
model : 62
stepping : 4
microcode : 0x428
cpu MHz : 2800.050
physical id : 1
siblings : 16
core id : 7
cpu cores : 8
apicid : 47
initial apicid : 47
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bugs :
bogomips : 5678.29
clflush size : 64
power management:
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
