The Travis failures we are experiencing started with the rollout of new trusty images about six days ago:
https://blog.travis-ci.com/2017-12-12-new-trusty-images-q4-launch
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <https://transient.nz/>
New Zealand
We are not the only users having problems:
https://github.com/travis-ci/travis-ci/issues
Kind regards,
Director
New Zealand
I have been able to reproduce build hangs locally in src/community with:
mvn -B -T4 -U -Prelease -PcommunityRelease -DskipTests clean install
The hangs occur *only* with Maven 3.5.2, -U, and -T4.
- Maven 3.5.0 -> no hang
- Single threaded (no -T) - > no hang
- No -U (so reduced downloads) -> no hang
The latest Travis release updated to Maven 3.5.2, causing the problem. Travis is blameless, and my endless tinkering with travis_wait and other settings in .travis.yml was to no avail. This is a Maven problem.
jstack shows clear evidence of a deadlock during multi-threaded dependency resolution (attached).
The build eventually recovers (some of the locks are a TIMED__WAIT).
GeoTools does not use -U because it has no SNAPSHOT dependencies and is thus unaffected.
Removing -T is not an option because we have seen hangs in the main build as well and the single-threaded build is too slow.
Kind regards,
Ben.
Kind regards,
Director
New Zealand
(attachments)
geoserver-community-maven-hang-jstack.txt (19.2 KB)
And here is another jstack while the build is hung at a different spot. There are no *.lock files in my local repository so the deadlock is not mediated by the filesystem.
Hung builds eventually complete after 30-45 minutes, but this is enough for Travis to notice their silence and kill them. Deadlock I think not livelock because zero CPU is being consumed.
Kind regards,
Ben.
Kind regards,
Check out the vibrant tech community on one of the world's most
Geoserver-devel mailing list
Director
New Zealand
(attachments)
geoserver-community-maven-hang-jstack-2.txt (28.1 KB)
Hi Ben,
thanks for the investigation!
Did you open a bug report?
Also, I’m wondering, can we use a custom version of Maven?
On Mon, Dec 18, 2017 at 9:42 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
The hangs occur only with Maven 3.5.2, -U, and -T4.
- Maven 3.5.0 → no hang
- No -U (so reduced downloads) → no hang
Kind regards,
Ben.
Kind regards,
Director
New Zealand
Geoserver-devel@anonymised.com.366…sourceforge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Andrea,
I have not yet filed a bug report.
I am testing a workaround to download and use Maven 3.5.0:
https://github.com/geoserver/geoserver/commit/a78d7c4711bdde1c853df523f5919a95cadd9359
The test Travis build is running on the debug-travis branch:
https://travis-ci.org/geoserver/geoserver/builds/317993402
Kind regards,
Ben.
On 18/12/17 21:50, Andrea Aime wrote:
Hi Ben,
Also, I'm wondering, can we use a custom version of Maven?
thus unaffected.
Kind regards,
Ben.
Kind regards,
Director
New Zealand
Director
New Zealand
Andrea,
the test Travis build passed so I applied the fix to master, 2.12.x, and 2.11.x. I also went through open pull requests, found three which had failed with the timeout error, and closed-reopened each to start a new Travis build the latest settings.
GeoTools may also be vulnerable. The lack of -U used on Travis might only reduce the risk. If anyone sees one of these timeouts "No output has been received in the last 10m0s, this potentially indicates a stalled build or something wrong with the build itself.", please let everyone know.
I will report the bug to the Maven maintainers.
Kind regards,
Ben.
On 18/12/17 22:56, Ben Caradoc-Davies wrote:
Andrea,
Kind regards,
Ben.
Hi Ben,
thus unaffected.
Kind regards,
Ben.
Kind regards,
Director
New Zealand
Director
New Zealand
All six builds passed (three branches and three pull requests). Travis status is green.
Director
New Zealand
Thanks Ben, that explains some issues I was having Friday.
Torben
On Mon, Dec 18, 2017 at 5:21 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Awesome, thanks Ben!
On Mon, Dec 18, 2017 at 1:14 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Director
New Zealand
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Reported:
[MNG-6323] Deadlock in multithreaded dependency resolution
https://issues.apache.org/jira/browse/MNG-6323
Director
New Zealand
