[Geoserver-devel] Travis hates our verbose builds
this morning I made the build go a bit further with JDK 7 and Travis welcomed my efforts with the following error message:
The log length has exceeded the limit of 4 Megabytes (this usually means that test suite is raising the same exception over and over).
Erk… seems a bit extreme, but hey, it’s given for free.
And indeed looking at a GeoServer build scroll by makes it difficult to see if things are going ok or not.
Besides tests printing on the standard output (normally, leftovers), the build is really logging a ton of exceptions… and it does because
we are indeed testing a number of exceptional conditions that should raise them.
Now, those are not really errors, it’s us testing that GeoServer responds to invalid requests with a service exception most of the time.
So, how about we turn down the build logging so that not even error messages are logged?
The build already sets up the the quietTests system variable to true, so that we run with the QUIET_LOGGING.properties profile,
something that is not up when running tests in the IDE, where the profile is instead TEST_LOGGING.properties.
So, I guess the proposal is, can we switch QUIET_LOGGING to use:
log4j.rootLogger=OFF, stdout
instead?
I’ve built geoserver with just a single thread and dumped the output to a file so that you can see how it looks:
https://dl.dropboxusercontent.com/u/2361103/build.log.gz
Unpacked it’s still 1.8MB, mostly due to a number of tests that do output large xml files for debugging purposes, we
might want to have a look at those and do some clean up.
As said, this would be only the output from maven, if you run tests from the IDE it would used TEST_LOGGING instead
and all exceptions would be logged as usual.
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Sat, Oct 5, 2013 at 6:53 AM, Andrea Aime <andrea.aime@anonymised.com>wrote:
Erk... seems a bit extreme, but hey, it's given for free.
build is really logging a ton of exceptions... and it does because
them.
Now, those are not really errors, it's us testing that GeoServer responds
instead?
+1
I've built geoserver with just a single thread and dumped the output to a
Unpacked it's still 1.8MB, mostly due to a number of tests that do output
Agreed.
Opinions?
All sounds good to me. Thanks for all the work setting up travis.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most
from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60134791&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
*Justin Deoliveira*
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive <https://twitter.com/j_deolive&gt;
