On Mon, Oct 24, 2016 at 6:36 PM, Ellis, Scott <SELLIS06@anonymised.com> wrote:
Andrea, do you have any insight on these issues?
Meh, I don't like very much being called out directly given that I had no
involvement in this (the thread, the
particular REST code in question, the documentation about it), if any core
developer wants to participate to the thread
they can, we all see the mails going on the list and can (and should) be
able to decide if we want to participate.
Probably no one bothered to look into this because a discussion on devel is
supposed to be about
the software development, not the usage, and there was no clear offer to
fix the code so far (a developer
here is someone that contributes to GeoServer, not someone that, while
being a developer on his own, uses it).
Not saying the issue is not valid, it certainly looks like it is, but
someone just looking for confirmation
of a bug can ask on the users list.
If you believe this is a harsh response, consider we're up to our eyeballs
of work, way too many users,
not enough active devs, and there is a lot of people trying to get direct
attention without contributing back squat, so, while I cannot
speak about others, I've become exceptionally sensitive to attempts of
pulling me by the jacket.
In any case, I have checked the history of CoverageResource and there is a
commit that seems
to relate to the topic of discussion:. History here:
https://github.com/geoserver/geoserver/commits/master/src/restconfig/src/main/java/org/geoserver/catalog/rest/CoverageResource.java
In particular, "GEOS-6874 Resolve conflation of catalog and native coverage
names."
Now, Kevin might want to chime in here (or not!) :-p
Regards
PS: the one commit of mine in that history is there due to our shallow
github history, it just happens
to be the first one in the part of history migrated from svn to github.
The rest of the history of that class is here:
https://github.com/geoserver/geoserver-history/commits/master/src/restconfig/src/main/java/org/geoserver/catalog/rest/CoverageResource.java
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
