I’m trying to get the trunk building so that I can do some work on the Excel plugin. A few of the modules are showing errors, one of which is wcs1_1. I can’t get the rangeset classes to generate. See the following result of a mvn install in the wcs1_1 directory:
- Error stacktraces are turned on.
[INFO] Scanning for projects…
[INFO] Building Web Coverage Service 1.1 Module
[INFO] task-segment: [install]
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting C:\geoserver\src\wcs1_1
[INFO] [javacc:jjtree {execution: jjtree}]
[INFO] Nothing to process - all grammars in C:\geoserver\src\wcs1_1\src\main\java\org\geoserver\wcs\kvp\rangesubset are up to date.
[INFO] [javacc:javacc {execution: javacc}]
[INFO] Nothing to process - all grammars in C:\geoserver\src\wcs1_1\target\generated-sources\jjtree are up to date.
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO] Copying 11 resources
[INFO] skip non existing resourceDirectory C:\geoserver\src\wcs1_1\src\main\resources
[INFO] Compiling 19 source files to C:\geoserver\src\wcs1_1\target\classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
C:\geoserver\src\wcs1_1\target\generated-sources\javacc\org\geoserver\wcs\kvp\rangesubset\SimpleNode.java:[5,7] cannot access Node
class file for Node not found
public class SimpleNode extends AbstractContentNode implements Node {
C:\geoserver\src\wcs1_1\target\generated-sources\javacc\org\geoserver\wcs\kvp\rangesubset\SimpleNode.java:[50,25] cannot find symbol
symbol : variable this
location: class org.geoserver.wcs.kvp.rangesubset.SimpleNode
C:\geoserver\src\wcs1_1\target\generated-sources\javacc\org\geoserver\wcs\kvp\rangesubset\SimpleNode.java:[80,7] operator != cannot be applied to org.geoserver.wcs.kvp.rangesubset.SimpleNode,
[INFO] Trace
org.apache.maven.BuildFailureException: Compilation failure
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:715)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLifecycle(DefaultLifecycleExecutor.java:556)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:535)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:387)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:348)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:180)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:328)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:138)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:362)
at org.apache.maven.cli.compat.CompatibleMain.main(CompatibleMain.java:60)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.plugin.CompilationFailureException: Compilation failure
at org.apache.maven.plugin.AbstractCompilerMojo.execute(AbstractCompilerMojo.java:516)
at org.apache.maven.plugin.CompilerMojo.execute(CompilerMojo.java:114)
at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:490)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:694)
… 17 more
[INFO] Total time: 7 seconds
[INFO] Finished at: Mon Apr 04 13:00:24 AKDT 2011
[INFO] Final Memory: 27M/64M
Any ideas?
Shane
