[Geoserver-devel] Trouble runing geoserver 1.7 from Eclipse
Hi all
I´m having trouble runing Geoserver 1.7 from eclipse.
I run the Start.java from the web module as a Java Application and i get this exceptions:
2009-11-23 23:52:53.095::INFO: Logging to STDERR via org.mortbay.log.StdErrLog
2009-11-23 23:52:53.220::INFO: jetty-6.1.8
23/Nov/2009 23:52:56 it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
2009-11-23 23:52:57.046:/geoserver:INFO: Initializing Spring root WebApplicationContext
23 Nov 23:52:57 INFO [context.ContextLoader] - Root WebApplicationContext: initialization started
23 Nov 23:52:57 INFO [support.XmlWebApplicationContext] - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@anonymised.com: display name [Root WebApplicationContext]; startup date [Mon Nov 23 23:52:57 GMT 2009]; root of context hierarchy
23 Nov 23:52:57 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/C:/GeoserverCodigoFonte/src/web/target/classes/applicationContext.xml]
23 Nov 23:52:57 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/C:/GeoserverCodigoFonte/src/gwc/target/classes/applicationContext.xml]
23 Nov 23:52:57 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/C:/GeoserverCodigoFonte/src/main/target/classes/applicationContext.xml]
23 Nov 23:52:57 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/C:/GeoserverCodigoFonte/src/rest/target/test-classes/applicationContext.xml]
23 Nov 23:52:57 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/C:/GeoserverCodigoFonte/src/rest/target/classes/applicationContext.xml]
23 Nov 23:52:57 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/C:/GeoserverCodigoFonte/src/wms/target/classes/applicationContext.xml]
23 Nov 23:52:57 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/C:/GeoserverCodigoFonte/src/wcs/target/classes/applicationContext.xml]
23 Nov 23:52:57 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/C:/GeoserverCodigoFonte/src/wfs/target/classes/applicationContext.xml]
23 Nov 23:52:57 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/C:/GeoserverCodigoFonte/src/validation/target/classes/applicationContext.xml]
23 Nov 23:52:57 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/C:/GeoserverCodigoFonte/src/wcs1_1/target/classes/applicationContext.xml]
23 Nov 23:52:57 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/C:/GeoserverCodigoFonte/src/wfs11/target/classes/applicationContext.xml]
23 Nov 23:52:57 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/C:/GeoserverCodigoFonte/src/web/target/classes/applicationSecurityContext.xml]
23 Nov 23:52:57 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/C:/GeoserverCodigoFonte/src/main/target/classes/applicationSecurityContext.xml]
23 Nov 23:52:57 INFO [support.XmlWebApplicationContext] - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
23 Nov 23:52:58 INFO [support.XmlWebApplicationContext] - Bean ‘resourceLoader’ is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
23 Nov 23:52:58 ERROR [geoserver.global] -
  • GEOSERVER_DATA_DIR: C:\GeoserverCodigoFonte\src\web\src\main\webapp\data
23 Nov 23:52:58 INFO [support.DefaultListableBeanFactory] - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [applicationState,applicationStateRegisterar,dispatcherMapping,gwcAppCtx,gwcXmlConfig,gwcGSConfig,gwcTLDispatcher,gwcDefaultStorageFinder,gwcMetaStore,gwcBlobStore,gwcStorageBroker,geowebcacheDispatcher,gwcServiceWMS,gwcServiceGMaps,gwcServiceMGMaps,gwcServiceVE,gwcServiceKML,gwcServiceWFS,gwcSeederThreadPoolExec,gwcSeedRestlet,gwcSeedFormRestlet,gwcReloadRestlet,gwcTileLayerRestlet,gwcBoundsRestlet,gwcFilterUpdateRestlet,gwcRestDispatcher,gwcProxyDispatcher,gwcUrlMapping,resourceLoader,extensions,rawCatalog,secureCatalog,geoServer2,geoServerLoader,config,geoServer,globalConfig,data,rawData,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,serviceStrategyFactory,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,customEditorConfigurer,dispatcher,filePublisher,jaiInitializer,defaultDataSecurityFactory,defaultCatalogSecurityFactory,disabledServiceChecker,catalogRepository,exceptionThrowingResource,testMapping,restWrapper,restletDispatcherMapping,wmsLoader,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsDescribeLayer,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsService2,wmsServiceDescriptor,wmsExceptionHandler,widthKvpParser,heightKvpParser,wmsFormatOptionsKvpParser,bgColorKvpParser,transparentKvpParser,tiledKvpParser,tilesOriginKvpParser,bufferKvpParser,paletteKvpParser,timeKvpParser,elevationKvpParser,validateSldKvpParser,sldKvpParser,startIndexKvpParser,wmsGetCapabilitiesKvpReader,describeLayerKvpReader,getMapKvpReader,getFeatureInfoKvpReader,getLegendGraphicKvpReader,wmsCapabilitiesXmlReader,getMapXmlReader,sldXmlReader,wmsGetCapabilitiesResponse,describeLayerResponse,getMapResponse,getFeatureInfoResponse,getLegendGraphicResponse,putStylesWrapper,wmsURLMapping,GIFLegendProducerFactory,JaiLegendProducerFactory,PNGLegendProducerFactory,PNGMapProducer,GeoTiffMapProducer,TiffMapProducer,GIFMapProducer,JPEGMapProducer,PDFMapProducerFactory,KMLMapProducer,KMZMapProducer,OpenLayersMapProducer,AtomGeoRSSMapProducer,RSSGeoRSSMapProducer,SVGMapProducer,kmlService,kmlServiceDescriptor,kmlURLMapping,superOverlayKvpParser,legendKvpParser,kmatrrKvpParser,kmscoreKvpParser,kmplacemarkKvpParser,metaTileCache,nativeSortingRegionator,externalSortingRegionator,geometryRegionator,randomRegionator,bestGuessRegionator,image,legend,scaleratio,scaleline,wcsLoader,wcs,wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage,wcsService2,wcsServiceDescriptor,wcsExceptionHandler,wcsGetCapabilitiesKvpReader,describeCoverageKvpReader,getCoverageKvpReader,wcsXmlReader,wcsGetCapabilitiesXmlReader,describeCoverageXmlReader,getCoverageXmlReader,wcsGetCapabilitiesResponse,describeCoverageResponse,getCoverageResponse,wcsURLMapping,wfsConfig,wfsRegisterar,wfsConfigRegisterar,filterFactory,wfsLoader,wfs,wfsServiceTarget,wfsLogger,wfsService,wfsInsertElementHandler,wfsUpdateElementHandler,wfsDeleteElementHandler,wfsNativeElementHandler,wfsService-1.0.0,wfsExceptionHandler,gml2SchemaBuilder,wfsXsd-1.0,xmlConfiguration-1.0,getCapabilitiesResponse,lockFeatureResponse-1.0,transactionResponse-1.0,geometryResponse,citeComplianceHack,wfsURLMapping,typeNameKvpParser,featureIdKvpParser,bboxKvpParser,filterKvpParser,cqlKvpParser,propertyNameKvpParser,maxFeatureKvpParser,srsNameKvpParser,sortByKvpParser,expiryKvpParser,resultTypeKvpParser,acceptVersionsKvpParser,acceptFormatsKvpParser,strictKvpParser,wfsFormatOptionsKvpParser,charsetKvpParser,wfsGetCapabilitiesKvpReader,describeFeatureTypeKvpReader,getFeatureKvpReader,getFeatureWithLockKvpReader,lockFeatureKvpReader,transactionKvpReader,releaseLockKvpReader,xmlReader-1.0.0,wfsGetCapabilitiesXmlReader,describeFetureTypeXmlReader,getFeatureXmlReader,getFeatureWithLockXmlReader,lockFeatureXmlReader,transactionXmlReader,gml2FeatureTypeEncoder,gml2OutputFormat,shapezipOutputFormat,geojsonOutputFormat,CSVOutputFormat,validation,validationConfig,validationRegisterar,validationConfigRegisterar,wcs111ServiceTarget,wcsLogger,wcs111Service,wcsService-1.1.0,wcsService-1.1.1,wcs111URLMapping,wcs111ExceptionHandler,ows11AcceptVersionsKvpParser,ows11SectionsKvpParser,wcs111RangeSubsetKvpParser,wcs111IdentifierKvpParser,wcs111BoundingBoxKvpParser,wcs111GridBaseCRSKvpParser,wcs111TimeSequenceKvpParser,wcs111GridTypeKvpParser,wcs111GridCSKvpParser,wcs111GridOriginKvpParser,wcs111GridOffsetsKvpParser,wcs111GetCapabilitiesKvpReader,wcs111DescribeCoverageKvpReader,wcs111GetCoverageRequestReader,wcs111StoreKvpParser,wcs-1.1.1-configuration,wcs111CapabilitiesRequestReader,wcs111DescribeCoverageRequestReader,wcs111GetCoverageRequestXMLReader,wcs111GetCapabilitiesResponse,wcs111DescribeCoverageResponse,wcs111GetCoverageMultipartResponse,wcs111GetCoverageStoreResponse,wcs111DispatcherMapping,wcs111TempStorageCleaner,wcs111TempStorageCleanerTask,wcs111timerFactory,wfsService-1.1.0,wfsExceptionHandler-1.1,wfsXsd-1.1,xmlConfiguration-1.1,gml3SchemaBuilder,xmlReader-1.1.0,wfsGetCapabilitiesXmlReader-1.1.0,describeFeatureTypeXmlReader-1.1.0,getFeatureTypeXmlReader-1.1.0,getFeatureWithLockXmlReader-1.1.0,lockFeatureXmlReader-1.1.0,transactionXmlReader-1.1.0,getGmlObjectXmlReader-1.1.0,gml3FeatureTypeEncoder,gml3OutputFormat,hitsOutputFormat,lockFeatureResponse-1.1,transactionResponse-1.1,featureResponse,filterChainProxy,restFilterInvocationInterceptor,restFilterDefinitionMap,filterInvocationInterceptor,httpSessionContextIntegrationFilterWithASCTrue,httpSessionContextIntegrationFilterWithASCFalse,logoutFilter,authenticationProcessingFilter,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,basicProcessingFilter,basicProcessingFilterEntryPoint,consoleExceptionTranslationFilter,owsExceptionTranslationFilter,rememberMeServices,authenticationManager,daoAuthenticationProvider,userDetailsService,operationSecurityInterceptor]; root of factory hierarchy
23 Nov 23:52:59 INFO [support.DefaultListableBeanFactory] - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [applicationState,applicationStateRegisterar,dispatcherMapping,gwcAppCtx,gwcXmlConfig,gwcGSConfig,gwcTLDispatcher,gwcDefaultStorageFinder,gwcMetaStore,gwcBlobStore,gwcStorageBroker,geowebcacheDispatcher,gwcServiceWMS,gwcServiceGMaps,gwcServiceMGMaps,gwcServiceVE,gwcServiceKML,gwcServiceWFS,gwcSeederThreadPoolExec,gwcSeedRestlet,gwcSeedFormRestlet,gwcReloadRestlet,gwcTileLayerRestlet,gwcBoundsRestlet,gwcFilterUpdateRestlet,gwcRestDispatcher,gwcProxyDispatcher,gwcUrlMapping,resourceLoader,extensions,rawCatalog,secureCatalog,geoServer2,geoServerLoader,config,geoServer,globalConfig,data,rawData,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,serviceStrategyFactory,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,customEditorConfigurer,dispatcher,filePublisher,jaiInitializer,defaultDataSecurityFactory,defaultCatalogSecurityFactory,disabledServiceChecker,catalogRepository,exceptionThrowingResource,testMapping,restWrapper,restletDispatcherMapping,wmsLoader,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsDescribeLayer,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsService2,wmsServiceDescriptor,wmsExceptionHandler,widthKvpParser,heightKvpParser,wmsFormatOptionsKvpParser,bgColorKvpParser,transparentKvpParser,tiledKvpParser,tilesOriginKvpParser,bufferKvpParser,paletteKvpParser,timeKvpParser,elevationKvpParser,validateSldKvpParser,sldKvpParser,startIndexKvpParser,wmsGetCapabilitiesKvpReader,describeLayerKvpReader,getMapKvpReader,getFeatureInfoKvpReader,getLegendGraphicKvpReader,wmsCapabilitiesXmlReader,getMapXmlReader,sldXmlReader,wmsGetCapabilitiesResponse,describeLayerResponse,getMapResponse,getFeatureInfoResponse,getLegendGraphicResponse,putStylesWrapper,wmsURLMapping,GIFLegendProducerFactory,JaiLegendProducerFactory,PNGLegendProducerFactory,PNGMapProducer,GeoTiffMapProducer,TiffMapProducer,GIFMapProducer,JPEGMapProducer,PDFMapProducerFactory,KMLMapProducer,KMZMapProducer,OpenLayersMapProducer,AtomGeoRSSMapProducer,RSSGeoRSSMapProducer,SVGMapProducer,kmlService,kmlServiceDescriptor,kmlURLMapping,superOverlayKvpParser,legendKvpParser,kmatrrKvpParser,kmscoreKvpParser,kmplacemarkKvpParser,metaTileCache,nativeSortingRegionator,externalSortingRegionator,geometryRegionator,randomRegionator,bestGuessRegionator,image,legend,scaleratio,scaleline,wcsLoader,wcs,wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage,wcsService2,wcsServiceDescriptor,wcsExceptionHandler,wcsGetCapabilitiesKvpReader,describeCoverageKvpReader,getCoverageKvpReader,wcsXmlReader,wcsGetCapabilitiesXmlReader,describeCoverageXmlReader,getCoverageXmlReader,wcsGetCapabilitiesResponse,describeCoverageResponse,getCoverageResponse,wcsURLMapping,wfsConfig,wfsRegisterar,wfsConfigRegisterar,filterFactory,wfsLoader,wfs,wfsServiceTarget,wfsLogger,wfsService,wfsInsertElementHandler,wfsUpdateElementHandler,wfsDeleteElementHandler,wfsNativeElementHandler,wfsService-1.0.0,wfsExceptionHandler,gml2SchemaBuilder,wfsXsd-1.0,xmlConfiguration-1.0,getCapabilitiesResponse,lockFeatureResponse-1.0,transactionResponse-1.0,geometryResponse,citeComplianceHack,wfsURLMapping,typeNameKvpParser,featureIdKvpParser,bboxKvpParser,filterKvpParser,cqlKvpParser,propertyNameKvpParser,maxFeatureKvpParser,srsNameKvpParser,sortByKvpParser,expiryKvpParser,resultTypeKvpParser,acceptVersionsKvpParser,acceptFormatsKvpParser,strictKvpParser,wfsFormatOptionsKvpParser,charsetKvpParser,wfsGetCapabilitiesKvpReader,describeFeatureTypeKvpReader,getFeatureKvpReader,getFeatureWithLockKvpReader,lockFeatureKvpReader,transactionKvpReader,releaseLockKvpReader,xmlReader-1.0.0,wfsGetCapabilitiesXmlReader,describeFetureTypeXmlReader,getFeatureXmlReader,getFeatureWithLockXmlReader,lockFeatureXmlReader,transactionXmlReader,gml2FeatureTypeEncoder,gml2OutputFormat,shapezipOutputFormat,geojsonOutputFormat,CSVOutputFormat,validation,validationConfig,validationRegisterar,validationConfigRegisterar,wcs111ServiceTarget,wcsLogger,wcs111Service,wcsService-1.1.0,wcsService-1.1.1,wcs111URLMapping,wcs111ExceptionHandler,ows11AcceptVersionsKvpParser,ows11SectionsKvpParser,wcs111RangeSubsetKvpParser,wcs111IdentifierKvpParser,wcs111BoundingBoxKvpParser,wcs111GridBaseCRSKvpParser,wcs111TimeSequenceKvpParser,wcs111GridTypeKvpParser,wcs111GridCSKvpParser,wcs111GridOriginKvpParser,wcs111GridOffsetsKvpParser,wcs111GetCapabilitiesKvpReader,wcs111DescribeCoverageKvpReader,wcs111GetCoverageRequestReader,wcs111StoreKvpParser,wcs-1.1.1-configuration,wcs111CapabilitiesRequestReader,wcs111DescribeCoverageRequestReader,wcs111GetCoverageRequestXMLReader,wcs111GetCapabilitiesResponse,wcs111DescribeCoverageResponse,wcs111GetCoverageMultipartResponse,wcs111GetCoverageStoreResponse,wcs111DispatcherMapping,wcs111TempStorageCleaner,wcs111TempStorageCleanerTask,wcs111timerFactory,wfsService-1.1.0,wfsExceptionHandler-1.1,wfsXsd-1.1,xmlConfiguration-1.1,gml3SchemaBuilder,xmlReader-1.1.0,wfsGetCapabilitiesXmlReader-1.1.0,describeFeatureTypeXmlReader-1.1.0,getFeatureTypeXmlReader-1.1.0,getFeatureWithLockXmlReader-1.1.0,lockFeatureXmlReader-1.1.0,transactionXmlReader-1.1.0,getGmlObjectXmlReader-1.1.0,gml3FeatureTypeEncoder,gml3OutputFormat,hitsOutputFormat,lockFeatureResponse-1.1,transactionResponse-1.1,featureResponse,filterChainProxy,restFilterInvocationInterceptor,restFilterDefinitionMap,filterInvocationInterceptor,httpSessionContextIntegrationFilterWithASCTrue,httpSessionContextIntegrationFilterWithASCFalse,logoutFilter,authenticationProcessingFilter,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,basicProcessingFilter,basicProcessingFilterEntryPoint,consoleExceptionTranslationFilter,owsExceptionTranslationFilter,rememberMeServices,authenticationManager,daoAuthenticationProvider,userDetailsService,operationSecurityInterceptor]; root of factory hierarchy
23 Nov 23:52:59 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name ‘wmsLoader’: Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
23 Nov 23:52:59 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘applicationState’ defined in URL [file:/C:/GeoserverCodigoFonte/src/web/target/classes/applicationContext.xml]: Cannot resolve reference to bean ‘data’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘data’ defined in URL [file:/C:/GeoserverCodigoFonte/src/main/target/classes/applicationContext.xml]: Cannot resolve reference to bean ‘geoServer2’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer2’ defined in URL [file:/C:/GeoserverCodigoFonte/src/main/target/classes/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.io.FileNotFoundException: Could not find services.xml under:C:\GeoserverCodigoFonte\src\web\src\main\webapp\data
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.vfny.geoserver.jetty.Start.main(Start.java:56)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘data’ defined in URL [file:/C:/GeoserverCodigoFonte/src/main/target/classes/applicationContext.xml]: Cannot resolve reference to bean ‘geoServer2’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer2’ defined in URL [file:/C:/GeoserverCodigoFonte/src/main/target/classes/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.io.FileNotFoundException: Could not find services.xml under:C:\GeoserverCodigoFonte\src\web\src\main\webapp\data
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
… 30 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer2’ defined in URL [file:/C:/GeoserverCodigoFonte/src/main/target/classes/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.io.FileNotFoundException: Could not find services.xml under:C:\GeoserverCodigoFonte\src\web\src\main\webapp\data
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:480)
… 45 more
Caused by: java.lang.RuntimeException: java.io.FileNotFoundException: Could not find services.xml under:C:\GeoserverCodigoFonte\src\web\src\main\webapp\data
at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:95)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:81)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
… 54 more
Caused by: java.io.FileNotFoundException: Could not find services.xml under:C:\GeoserverCodigoFonte\src\web\src\main\webapp\data
at org.geoserver.config.util.LegacyImporterSupport.reader(LegacyImporterSupport.java:19)
at org.geoserver.config.util.LegacyLoggingImporter.imprt(LegacyLoggingImporter.java:34)
at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:92)
… 58 more
2009-11-23 23:52:59.278::WARN: Failed startup of context org.mortbay.jetty.webapp.WebAppContext@anonymised.com{/geoserver,src/main/webapp}
… 30 more
… 45 more
… 54 more
… 58 more
2009-11-23 23:52:59.294::WARN: Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘applicationState’ defined in URL [file:/C:/GeoserverCodigoFonte/src/web/target/classes/applicationContext.xml]: Cannot resolve reference to bean ‘data’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘data’ defined in URL [file:/C:/GeoserverCodigoFonte/src/main/target/classes/applicationContext.xml]: Cannot resolve reference to bean ‘geoServer2’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer2’ defined in URL [file:/C:/GeoserverCodigoFonte/src/main/target/classes/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.io.FileNotFoundException: Could not find services.xml under:C:\GeoserverCodigoFonte\src\web\src\main\webapp\data:
2009-11-23 23:52:59.513::INFO: Started SocketConnector@anonymised.com:8080
Can you give me some help, plz?
Thanks
Emanuel Rita ha scritto:
Hi all
2009-11-23 23:52:59.513::INFO: Started SocketConnector@anonymised.com:8080 <http://SocketConnector@anonymised.com:8080>
It seems you never built your checkout with Maven (with "mvn install")
otherwise you should have an empty, but valid, data directory instead
of an empty folder.
I usually run GeoServer in the IDE by pointing it at the release data
directory adding a system variable to the runner configuration, something like:
-DGEOSERVER_DATA_DIR=/home/aaime/devel/gstrunk/data/release
Hope this helps
Andrea Aime
OpenGeo - http://opengeo.org
