[Geoserver-devel] trunk back in shape
So trunk is back in shape and passing all unit tests. If someone else
can update both geotools trunk and geoserver trunk and do full builds to
verify that would be peachy.
Onto cite testing... stay tuned.
-Justin
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
IOn Monday 19 November 2007 01:13:32 am Justin Deoliveira wrote:
I did. GT build wen't ok but geoserver fails:
[INFO] ----------------------------------------------------------------------------
[INFO] Building Main Module
[INFO] [clean:clean]
[INFO] Deleting
directory /home/gabriel/svn/geoserver/1.7.x/geoserver/main/target
[INFO] Deleting
directory /home/gabriel/svn/geoserver/1.7.x/geoserver/main/target/classes
[INFO] Deleting
directory /home/gabriel/svn/geoserver/1.7.x/geoserver/main/target/test-classes
[INFO] Deleting
directory /home/gabriel/svn/geoserver/1.7.x/geoserver/main/target/site
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 118 source files
to /home/gabriel/svn/geoserver/1.7.x/geoserver/main/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/home/gabriel/svn/geoserver/1.7.x/geoserver/main/src/main/java/org/vfny/geoserver/global/FeatureTypeInfo.java:
[13,28] cannot find symbol
symbol : class FactoryConfigurationError
[1131,25] cannot find symbol
location: class org.vfny.geoserver.global.FeatureTypeInfo
not sure if its something missing on my side though, gonna check later.
Gabriel
-Justin
This exception was deprecated since GeoTools 2.1. A long @deprecated statement
explain why. Code that still using it are wrong, since this exception is never
thrown since a few Geotools release. In Geotools 2.5, is was removed.
The fix is only to replace FactoryConfigurationError by FactoryRegistryException.
  Martin
I probably just need to update gt trunk then. Will do it and make the
appropriate changes in GeoServer.
-Justin
  Martin
Defy all challenges. Microsoft(R) Visual Studio 2005.
Geoserver-devel mailing list
!DSPAM:4007,47417eb456931336712104!
Justin Deoliveira
