What's the user/password for this bit?
Or is it something that I need to sign up for an OGC CITE account to get
access to?
If so, I'd suggest not making it a default part of the checkout for the
gs-trunk tree, since some folks won't be able to check it out and it may
cause them to think that their checkout didn't complete correctly.
--saul
Right... I totally forgot that this was password protected. My bad. I
will removed the external link for now. Thanks for the catch Saul.
-Justin
access to?
--saul
Defy all challenges. Microsoft(R) Visual Studio 2005.
Geoserver-devel mailing list
!DSPAM:4007,4743c18c187412090977483!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Hum, I just updated and the external load of the ogc test suite
started without asking me for a password:
Caricamento di oggetto esterno in 'community\cite\engine'
A community\cite\engine\test
A community\cite\engine\LICENSE.txt
A community\cite\engine\setup
A community\cite\engine\setup\ant-contrib
A community\cite\engine\setup\ant-contrib\LICENSE.txt
A community\cite\engine\setup\ant-contrib\README.txt
A community\cite\engine\setup\ant-contrib\ant-contrib.jar
A community\cite\engine\setup\UserFilesRealm
the issue is that it was so slow that eventually svn just locked
up and I had to kill it the hard way (CTRL-C was no good).
So I guess the external link is still alive?
Well there are two external links, one for the engine which you don't
need a password for, it in sourceforge svn. The other link is to the
tests which are in password protected ogc svn.
I have now disabled the link to the engine code as well since that
module is not really used. Perhaps a better alternative is to just
provide instructions in the README to checkout the sources manually.
And yes... I refuse to store a binary copy of the engine in the
repository :P.
-Justin
!DSPAM:4007,474458dd83967082231907!
Justin Deoliveira
Guess so... not everybody is going to run the cite tests manually
anyways?
repository :P.
Oohh... and why not? (just kidding)
