[Geoserver-devel] Trying to call request on Apache Server
Hello,
I am facing one problem while working on GeoServer. I am working on
getfeatureinfo. I have written a Java script for my application where I am
trying to send the request using URL on Geoserver (i.e localhost:8080) which
I want it to reflect on Apache Server. But unfortunately it is reflecting on
Geoserver not on Apache Server URL (i.e localhost:8081).
The code is written here, if someone can please help me out to resolve my
problem, it will be highly appreciable.
Code:
map.events.register('click', map, function (e) {
                    document.getElementById('nodelist').innerHTML =
"Loading... please wait...";
                    var params = {
                        REQUEST: "GetFeatureInfo",
                        EXCEPTIONS: "application/vnd.ogc.se_xml",
                        BBOX: map.getExtent().toBBOX(),
                        SERVICE: "WMS",
                        INFO_FORMAT: 'text/html',
                        QUERY_LAYERS: map.layers[6].params.LAYERS,
                        FEATURE_COUNT: 50,
                        Layers: 'poll_camp:abdasa_pre',
                        WIDTH: map.size.w,
                        HEIGHT: map.size.h,
                        format: format,
                        styles: map.layers[6].params.STYLES,
                        srs: map.layers[6].params.SRS};
                    // handle the wms 1.3 vs wms 1.1 madness
                    if(map.layers[0].params.VERSION == "1.3.0") {
                        params.version = "1.3.0";
                        params.j = parseInt(e.xy.x);
                        params.i = parseInt(e.xy.y);
                    } else {
                        params.version = "1.1.1";
                        params.x = parseInt(e.xy.x);
                        params.y = parseInt(e.xy.y);
                    // merge filters
OpenLayers.loadURL("http://192.168.10.225:8080/geoserver/wms", params, this,
setHTML, setHTML);
                     OpenLayers.Event.stop(e);
Calls Function setHTML from given below code:
function setHTML(response){
   alert(response);
response.responseText;
Please guide me if I have missed out something on my above pasted code. Its
urgent!
Krunal
View this message in context: http://osgeo-org.1560.n6.nabble.com/Trying-to-call-request-on-Apache-Server-tp5005192.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
It sounds as though you are running into the Same-Origin Policy enforced by all modern browsers: http://en.wikipedia.org/wiki/Same_origin_policy
The usual technique for dealing with this is to use Apache to proxy GeoServer so that it appears on the same port as your OpenLayers application. You can use the ProxyPass directive (enabled by the mod_proxy and mod_proxy_http modules) to configure this.
David Winslow
OpenGeo - http://opengeo.org/
On Fri, Sep 28, 2012 at 8:08 AM, krunal <krunalrp15@anonymised.com> wrote:
Hello,
Code:
map.events.register(‘click’, map, function (e) {
document.getElementById(‘nodelist’).innerHTML =
“Loading… please wait…”;
var params = {
REQUEST: “GetFeatureInfo”,
EXCEPTIONS: “application/vnd.ogc.se_xml”,
SERVICE: “WMS”,
INFO_FORMAT: ‘text/html’,
FEATURE_COUNT: 50,
Layers: ‘poll_camp:abdasa_pre’,
WIDTH: map.size.w,
HEIGHT: map.size.h,
format: format,
if(map.layers[0].params.VERSION == “1.3.0”) {
params.version = “1.3.0”;
} else {
params.version = “1.1.1”;
// merge filters
OpenLayers.loadURL(“http://192.168.10.225:8080/geoserver/wms”, params, this,
setHTML, setHTML);
alert(response);
urgent!
Krunal
Got visibility?
Most devs has no idea what their production app looks like.
Find out how fast your code is with AppDynamics Lite.
http://ad.doubleclick.net/clk;262219671;13503038;y?
http://info.appdynamics.com/FreeJavaPerformanceDownload.html
Geoserver-devel mailing list
