[Geoserver-devel] Trying to understand Java 11 failures
Java 11 builds keep on being plagued by random failures, but lately, they are almost guaranteed.
The starting point for the build fail is not always the same, it happens in different modules, but once
there is an error, everything falls apart.
See for example this build:
https://build.geoserver.org/view/geotools/job/geotools-java11/489/consoleFull
After the errors in mosaic, the log of the feature-pregeneralized module, while not reporting errors,
state the following:
[INFO] <b>--- maven-resources-plugin:3.1.0:resources (default-resources) @ gt-feature-pregeneralized ---
</b>[INFO] Using 'UTF-8' encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory /tmp/jenkins-c559144f/workspace/java11/geotools/modules/plugin/feature-pregeneralized/src/main/resources
[INFO]
[INFO] <b>--- maven-compiler-plugin:3.8.0:compile (default-compile) @ gt-feature-pregeneralized ---
</b>[INFO] No sources to compile
[INFO]
[INFO] <b>--- maven-resources-plugin:3.1.0:testResources (default-testResources) @ gt-feature-pregeneralized ---
[INFO] skip non existing resourceDirectory /tmp/jenkins-c559144f/workspace/java11/geotools/modules/plugin/feature-pregeneralized/src/test/resources
This is however not true, there definitely sources, and there are files there:
https://github.com/geotools/geotools/tree/84d6dc79f544430bdb6bdec7fa3a7fb89bb65229/modules/plugin/feature-pregeneralized/src/main/resources
https://github.com/geotools/geotools/tree/84d6dc79f544430bdb6bdec7fa3a7fb89bb65229/modules/plugin/feature-pregeneralized/src/test/resources
So it looks like the file system suddenly gives up, or at least, Java is not able to see it any longer.
I tried to see if there is a “too many open files” error somewhere, but could not find any.
Looking at the errors, it seems to be affecting both surefire (which is running in its own separate JVMs) and the main
maven JVM, which is running compiles and the like, indeed, right after the failures, it also attempts re-downloading dependencies
that were already downloaded, like jackson jars, see for example this build console output, search for jackson-core 2.9.10 (there
is also a 2.9.6 in the build, used by maven itself), you can see it being succesfully downloaded at the beginning, while
building gt-main, and then after the first failure, it tries to re-download it again, as if the maven local repository got emptied somehow.
The GeoTools failures to build are likely affecting also GeoServer, as a revert of a commit that is causing a concurrency failure in the WFS tests
never got baked into a java 11 jar for the GeoServer java 11 build to use.
I’m not seeing a smoking gun, but maybe the above description may trigger a light in some of your reading this message.
What would cause this, that does not happen with a Java 8 build.
Btw, I’ve noticed that the Java 11 build is not the latest, it’s a 11.0.3 while 11.0.4 is out already… checked the changelog
but don’t see anything file related:
https://www.oracle.com/technetwork/java/javase/2col/11-0-4-oracle-bugfixes-5480115.html
== Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Been building the master branch with OpenJDK 11 from AdoptOpenJDK all day, tried to make
a few runs every now and then, found a image comparison failure that I’ve fixed, with that,
no more failures, no file system issues… seems an Amazon fleet specific mystery…
Anyone that can reproduce these issues?
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
tried a few more things on the build server, with no success:
  • Reduced build parallelism to 1
  • Switched to Maven 3.6.2
  • Removed all QA checks
  • Skipping formatting checks
    I’ve also noticed that the normal build has the java.tmpdir set, so copied that setting over.
    Even with all of the above applied at the same time, the build still failed.
I’ve also tried different positions for the local maven repo (the current build uses a separate one,
maybe to make sure there is no conflict with java 8 builds) but that did not help either.
No idea of what else to try…
On Thu, Oct 10, 2019 at 6:47 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Oct 10, 2019 at 11:14 AM Andrea Aime <andrea.aime@anonymised.com8…> wrote:
[INFO]
[INFO]
This turned out not to be the case, with enough pressure the tests are failing also on java 8, they just require more threads
and more iterations. I’ve opened a ticket about it, and created a PR to disable the tests until we can do something about it*:
https://osgeo-org.atlassian.net/browse/GEOS-9367
Hi Andrea,
using Java 11 (OpenJDK 11 from AdoptOpenJDK) I get the same results as you.
I have isolated this two errors as the origin:
java.lang.NullPointerException
at java.xml/com.sun.org.apache.xerces.internal.dom.ParentNode.nodeListGetLength(ParentNode.java:697)
at java.xml/com.sun.org.apache.xerces.internal.dom.ParentNode.getLength(ParentNode.java:725)
at org.geotools.xsd.impl.BindingPropertyExtractor.getSequenceElement(BindingPropertyExtractor.java:397)
at org.geotools.xsd.impl.BindingPropertyExtractor.isUnboundedSequence(BindingPropertyExtractor.java:363)
at org.geotools.xsd.impl.BindingPropertyExtractor.properties(BindingPropertyExtractor.java:82)
at org.geotools.xsd.Encoder.encode(Encoder.java:990)
… and:
java.util.ConcurrentModificationException
at java.base/java.util.HashMap$HashIterator.nextNode(HashMap.java:1493)
at java.base/java.util.HashMap$EntryIterator.next(HashMap.java:1526)
at java.base/java.util.HashMap$EntryIterator.next(HashMap.java:1524)
at org.geoserver.catalog.impl.ModificationProxyCloner.cloneMap(ModificationProxyCloner.java:274)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:108)
at com.sun.proxy.$Proxy43.getGML(Unknown Source)
at org.geoserver.wfs.xml.GML3OutputFormat.write(GML3OutputFormat.java:219)
at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:198)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:1031)
Chatting whit Fernando looks like he made some interesting discoveries, I will let him follow up on this thread :slight_smile:
Best regards,
Nuno Oliveira
On Sat, 2019-10-12 at 17:45 +0200, Andrea Aime wrote:
On Thu, Oct 10, 2019 at 11:14 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
[INFO]
[INFO]
Geoserver-devel mailing list
[Geoserver-devel@anonymised.comsts.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
experts!
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Following up on the discussion in the PMC meeting:
Torben
On Thu, Oct 10, 2019 at 2:15 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
[INFO]
[INFO]
Torben Barsballe
Software Engineer
Planet Federal
tbarsballe@anonymised.com.
Hi Torben,
thanks for testing it out. As a curiosity, is the build back to use the fleet, or is it using the
build server local hardware? At 50 minutes it’s sure slow, but still beats a failing build.
I’ve swapped it back to the fleet for now.
If we were to use the master node, I’d want to add a label to the java11 jobs so that they are the only ones which run on it (especially since other jobs may rely on resources not available on master). I could take a look at actually doing that sometime next week.
Torben
Torben Barsballe
Software Engineer
Planet Federal
