Due to recent problems cross platform with formatting i have turned auto
formatting off. It can be re enabled by editing one line in the root
pom.xml when we actually lick this problem.
I believe we have the extended character problem solved as long as you
running with a iso-8859-1 locale. But I still cant figure out the
end-of-line thing.
An example is KMLWriterTest.java in the test module. I tried formatting
it in both windows and linux today and still get eol problems. Which is
wierd because i can not see any differences from that file then with
other files in that module.
They all have the same svn properties set and file encoding... so i am
at a loss.
For the meantime i suggest we adopt a strategy of developers formatting
manually when they commit. Or doing a batch format when it comes release
time. Any thoughts?
-Justin
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Justin Deoliveira ha scritto:
end-of-line thing.
at a loss.
time. Any thoughts?
Go for the batch format. Formatting every time is good too provided the
formatting does not hide the change, which may happen if you're editing
a file that was previously committed without formatting it.
