Hi everyone.
Im going through the eclipse quick start doc, and im busy importing geoserver into eclipse, and there are two projects that show up as “config”. Wouldn’t that cause errors in eclipse? Which is which? Thanks
Gerhard Goosen
Hi everyone.
Gerhard Goosen
It seems that the config that is listed first, was generated somehow? Its not under subversion…
From: geoserver-devel-bounces@lists.sourceforge.net [mailto:geoserver-devel-bounces@lists.sourceforge.net] On Behalf Of Gerhard Goosen
Sent: 05 July 2006 12:03 PM
To: geoserver-devel@lists.sourceforge.net
Subject: [Geoserver-devel] two config project when importing into eclipse
Hi everyone.
Gerhard Goosen
The config plugin moved from config to maven/config. But you still had .preject and .classpath files in the old config directory so subversion didn't remove the directory and files when you updated.
You can safely remove the old config directory and it should be fine.
-Justin
*From:* geoserver-devel-bounces@lists.sourceforge.net [mailto:geoserver-devel-bounces@lists.sourceforge.net] *On Behalf Of *Gerhard Goosen
*Sent:* 05 July 2006 12:03 PM
*To:* geoserver-devel@lists.sourceforge.net
*Subject:* [Geoserver-devel] two config project when importing into eclipseHi everyone.
Gerhard Goosen
!DSPAM:1004,44ab94fa32901527717022!
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642!DSPAM:1004,44ab94fa32901527717022!
Geoserver-devel mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:1004,44ab94fa32901527717022!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Hi everyone.
I am trying to run mvn jetty6:run from eclipse, following the instructions in the http://docs.codehaus.org/display/GEOSDEV/3+Eclipse+Quickstarts doc, but I get this error, when executing the external tool.
FATAL ERROR in native method: No transports initialized
Transport dt_socket failed to initialize, rc = 509.
Any help will be appreciated thanks,
Gerhard Goosen
Hi Gerhard,
I spent some time looking at this and it appears that the way we have been doing this is pretty unstable. It works for me on linux pretty well. However on windows it appears to work half of the time. Who knows...
I have come up with another solution I think works nicer. Its basically the same thing but not running through an external program, just running maven directly with java.
I will reopen the jira issue.
-Justin
Hi everyone.
I am trying to run *mvn jetty6:run *from eclipse, following the instructions in the http://docs.codehaus.org/display/GEOSDEV/3+Eclipse+Quickstarts doc, but I get this error, when executing the external tool.
Gerhard Goosen
!DSPAM:1004,44acaf6e170211804284693!
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642!DSPAM:1004,44acaf6e170211804284693!
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:1004,44acaf6e170211804284693!
Justin Deoliveira
http://topp.openplans.org
