[Geoserver-devel] [udig-dev] ConcurrentModificationException on MemoryDataStore Layer
I pushed Revert commit to Geotools master (c61f73264b687d6ee25b9d2f85ff2d22d9c59686).
I’m going to prepare another pull request against GeoTools but will run test in GeoServer first.
Sorry for any inconvenience!
  • Frank
2015-11-02 21:53 GMT+01:00 Frank Gasdorf <fgdrf@anonymised.com>:
Interessting and Sure, going to have a look at. Wondering because I refactored to preserve ordering, tests in GeoTools are fine.
2015-11-02 21:17 GMT+01:00 Andrea Aime <andrea.aime@anonymised.com>:
Hi Jody and Frank,
it looks like the changes to MemoryDataStore are breaking tests in GeoServer:
Tests run: 2, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.652 sec <<< FAILURE!
testEscapes(org.geoserver.wfs.response.CSVOutputFormatTest) Time elapsed: 501 sec <<< FAILURE!
org.junit.ComparisonFailure: expected:<A l[abel with “quotes”]> but was:<A l[ong label
with windows
newlines]>
at org.junit.Assert.assertEquals(Assert.java:115)
at org.junit.Assert.assertEquals(Assert.java:144)
at org.geoserver.wfs.response.CSVOutputFormatTest.testEscapes(CSVOutputFormatTest.java:118)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
The test in question is indeed using a MemoryDataStore. I checked which other parts of GeoServer tests
might be affected, came up with the following list (only including what’s in supported land):
find . -name “*.java” | xargs grep MemoryDataStore
./wms/src/test/java/org/geoserver/wms/svg/SVGMapProducerTest.java:import org.geotools.data.memory.MemoryDataStore;
./wms/src/test/java/org/geoserver/wms/svg/SVGMapProducerTest.java: MemoryDataStore ds = new MemoryDataStore();
./wms/src/test/java/org/geoserver/wms/WMSMockData.java:import org.geotools.data.memory.MemoryDataStore;
./wms/src/test/java/org/geoserver/wms/WMSMockData.java: private MemoryDataStore dataStore;
./wms/src/test/java/org/geoserver/wms/WMSMockData.java: dataStore = new MemoryDataStore();
./wms/src/test/java/org/geoserver/wms/WMSMockData.java: dataStore.setNamespaceURI(“http://geoserver.org”); // required for GeoTools 12 implemetnation of MemoryDataStore
./wms/src/test/java/org/geoserver/wms/WMSMockData.java: * Creates a vector layer with associated FeatureType in the internal MemoryDataStore with the
./wms/src/main/java/org/geoserver/wms/map/GetMapXmlReader.java:import org.geotools.data.memory.MemoryDataStore;
./wms/src/main/java/org/geoserver/wms/map/GetMapXmlReader.java: MemoryDataStore reTypedDS = new MemoryDataStore(reader);
./wms/src/main/java/org/geoserver/wms/map/GetMapKvpRequestReader.java:import org.geotools.data.memory.MemoryDataStore;
./wms/src/main/java/org/geoserver/wms/map/GetMapKvpRequestReader.java: MemoryDataStore reTypedDS = new MemoryDataStore(new ForceCoordinateSystemFeatureReader(
./web/demo/src/main/java/org/geoserver/web/crs/CRSAreaOfValidityMapBuilder.java:import org.geotools.data.memory.MemoryDataStore;
./web/demo/src/main/java/org/geoserver/web/crs/CRSAreaOfValidityMapBuilder.java: MemoryDataStore ds = new MemoryDataStore();
./wfs/src/test/java/org/geoserver/wfs/response/CSVOutputFormatTest.java:import org.geotools.data.memory.MemoryDataStore;
./wfs/src/test/java/org/geoserver/wfs/response/CSVOutputFormatTest.java: MemoryDataStore data = new MemoryDataStore();
Could you have a look?
On Sat, Oct 31, 2015 at 1:26 PM, Frank Gasdorf <fgdrf@anonymised.com> wrote:
Hello folks,
I updated the initial pull request. Additional to the internal ConcurrentSkipListMap usage I synched the access to internal HashMaps (memory & schema objects) to avoid issues with concurrent access (createSchema, removeSchema (see pull https://github.com/geotools/geotools/pull/1022) and addFeatures and features() methodes)
Do you have any comments or requests for change on the outstanding pull request https://github.com/geotools/geotools/pull/1002
Hope anybody of you can have a look at while I start working on the pull to backport it into 14.x
Thanks a lot
  • Frank
udig-dev mailing list
udig-dev@anonymised.com.
To change your delivery options, retrieve your password, or unsubscribe from this list, visit
https://locationtech.org/mailman/listinfo/udig-dev
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
2015-09-13 9:09 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com>:
On Thu, Sep 10, 2015 at 11:13 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
One coud use a quadtree index instead, it can be modified without rebuilding it, but it’s more prone to degeration to linked list,
the STRTree is packed and optimized for balancing, but as you say, it’s a pain if stuff gets modified.
I don’t think any of the JTS indexes is thread safe.
Ing. Andrea Aime
@geowolf
Technical Lead
If you change the functionality, change the test to match. There should now be several feature collection implementations to choose from so code that requires a TreeSet based functionality has a migration path.
The index needs to get rebuilt each time a feature is modified, so other than that overhead (which could be pushed off until “commit” ) it should be workable. The List should not be a problem, as it offers you a bit of independence (at the cost of possibly traversing through out of date information).
Since its not an “Ordered” DataStore that should preserve order I’d suggest to remove these tests. Opinions?
I’m wondering how you would think about this “proposal”. However, STRtree internal creates a new List every type the Index is requested. I haven’t investigated thread savety of STRtree yet. Maybe anybody of you has much more experiance than me to give feedback on that
