[Geoserver-devel] Unable to create an ImageMosaic store using a PostGIS tile index (v2.8.2)
No luck on the geoserver-users group for this so trying dev. Thanks.
Ciao Jason,
I am going to answer on the other ML as the user ML is the right one
for this kind of answers.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Wed, Mar 9, 2016 at 7:35 PM, Jason Newmoyer
---------- Forwarded message ----------
Date: Fri, Feb 26, 2016 at 4:14 PM
Subject: Unable to create an ImageMosaic store using a PostGIS tile index
(v2.8.2)
To: GeoServer Mailing List List <geoserver-users@lists.sourceforge.net>
Hi GeoServer Users,
I am unable to create an ImageMosaic store using a PostGIS tile index. I am
also unable to get GS to produce any meaningful error message.
This is version: GeoServer 2.8.2
Here are my various config files. I have verified my JNDC datasource is
available by creating a PostGIS/JNDI store using it to create a layer. Also
I can create an ImageMosaic from the geotiffs I'm using by
removing all the config files and allowing GeoServer to create the ShapeFile
index for me. Previewing the layer works fine when doing that.
When creating the store, I have tried pointing the URL to the directory
where the config files reside, and also directly to the layer.properties.
From the docs I wasn't sure which is the correct way.
Thanks!
layer.properties
Levels=0.001000000000000038,0.0010000000000000063
0.001987500000000075,0.0020000000000000126
0.00397500000000015,0.004000000000000025
0.0079500000000003,0.00796969696969702
0.0159000000000006,0.01593939393939404
0.0318000000000012,0.03187878787878808
0.05300000000000201,0.06188235294117687
0.07950000000000301,0.11688888888888964
0.15900000000000603,0.21040000000000134
Heterogeneous=false
AbsolutePath=false
Name=hires
TypeName=tiles_hires_view
Caching=false
ExpandToRGB=false
LocationAttribute=location
SuggestedSPI=it.geosolutions.imageioimpl.plugins.tiff.TIFFImageReaderSpi
CheckAuxiliaryMetadata=false
LevelsNum=9
datastore.properties
SPI=org.geotools.data.postgis.PostgisNGJNDIDataStoreFactory
jndiReferenceName=mydatabase
Loose\ bbox=true
preparedStatements=false
indexer.properties
Schema=*bbox:Polygon,location:String,created:java.util.Date
PropertyCollectors=TimestampFileNameExtractorSPI[timeregex](created)
TimeAttribute=created
AbsolutePath=false
Caching=false
CanBeEmpty=false
#ExpandToRGB=false
UseExistingSchema=true
timeregex.properties (is this even relevant since my timestamps come from
the database table?
regex=[0-9]{8}T[0-9]{9}Z(\?!.\*[0-9]{8}T[0-9]{9}Z.\*)
Here is my table in PostGIS (a view actually):
CREATE OR REPLACE VIEW tiles_hires_view AS
SELECT concat(tile.name, '.tif') AS location,
    tile.created,
    tile.bbox,
    layer.name AS layer
   FROM tile
     JOIN layer ON tile.layer = layer.id
  WHERE layer.name = 'hires'::text;
Here is the stacktrace in the log:
2016-02-26 13:50:19,349 INFO [geoserver.web] - Getting list of coverages for
saved store file:data/imagery/hires/hires.properties
java.lang.RuntimeException: Could not list layers for this store, an error
occurred retrieving them: Failed to create reader from
file:data/imagery/hires/hires.properties and hints null
at
org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:151)
at
org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:59)
at
org.geoserver.web.wicket.GeoServerDataProvider.fullSize(GeoServerDataProvider.java:242)
at
org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.updateMatched(GeoServerTablePanel.java:567)
at
org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.<init>(GeoServerTablePanel.java:560)
at
org.geoserver.web.wicket.GeoServerTablePanel.<init>(GeoServerTablePanel.java:172)
at
org.geoserver.web.wicket.GeoServerTablePanel.<init>(GeoServerTablePanel.java:96)
at org.geoserver.web.data.layer.NewLayerPage$1.<init>(NewLayerPage.java:106)
at org.geoserver.web.data.layer.NewLayerPage.<init>(NewLayerPage.java:106)
at
org.geoserver.web.data.store.CoverageStoreNewPage.onSuccessfulSave(CoverageStoreNewPage.java:79)
at
org.geoserver.web.data.store.CoverageStoreNewPage.onSave(CoverageStoreNewPage.java:70)
at
org.geoserver.web.data.store.AbstractCoverageStorePage$1.onSubmit(AbstractCoverageStorePage.java:116)
at
org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68)
at
org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143)
at
org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
at
org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
at
org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
at
org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at
org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at
org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at
org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at
at
at
org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at
at
at
org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at
at
at
org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at
at
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:83)
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at
at
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at
at
org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at
org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at
org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at
org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at
org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at
org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at
org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
at
org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:110)
at
org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:499)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
at
org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
at
org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at
org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
at
org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: Failed to create reader from
at
org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1443)
at
org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1369)
at
org.geoserver.catalog.impl.CoverageStoreInfoImpl.getGridCoverageReader(CoverageStoreInfoImpl.java:59)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at
org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:146)
at com.sun.proxy.$Proxy68.getGridCoverageReader(Unknown Source)
at
org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:90)
... 111 more
Jason Newmoyer
Newmoyer Geospatial Solutions
843.606.0424
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785111&iu=/4140
Geoserver-devel mailing list
