Thank you Jody. I’m trying the internal geofence server but I can’t figure out how to debug it inside eclipse. When I start geoserver with mvn jetty:run… it will start successfully and I can access the geofence GUI including the Geofence Data Rules and Geofence Admin Rules links that show on the geoserver console.
But when I start inside eclipse by launching Start.java the internal geofence server will not run and shows exception (listed below) when I click the data-rules link on the console. It would appear that this is a known issue as shown by https://github.com/geoserver/geofence/issues/56 and the comment there…”This issue in particular prevents developing GeoServer + GeoFence using Eclipse the “normal” way, with Start.java, one has to use mvn jetty:run with the right command line options instead”.
Running with mvn jetty appears to be a severely limited source level debug environment. While a remote debugger can be attached, any edits to source code would simply be recompiled in the eclipse workspace but not in the external build that mvn jetty:run is executing.
Is there a way to eclipse-debug geoserver while running the internal geofence server? I can hardly see an advantage to using the internal server if not. But the external geofence doesn’t give me much of a source level debug capability either.
How can I run/debug/edit my geoserver service under development while using the internal geofence server?
Thanks for any comments…Walter Stovall – Byers Engineering Company.
org.apache.wicket.WicketRuntimeException: Can’t instantiate page using constructor public org.geoserver.geofence.web.GeofenceServerPage()
at org.apache.wicket.session.DefaultPageFactory.createPage(DefaultPageFactory.java:212)
at org.apache.wicket.session.DefaultPageFactory.newPage(DefaultPageFactory.java:57)
at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.newPage(BookmarkablePageRequestTarget.java:298)
at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.getPage(BookmarkablePageRequestTarget.java:320)
at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.processEvents(BookmarkablePageRequestTarget.java:234)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:228)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
at org.apache.wicket.session.DefaultPageFactory.createPage(DefaultPageFactory.java:192)
… 94 more
Caused by: java.lang.NullPointerException
at org.hibernate.impl.SessionFactoryImpl.getClassMetadata(SessionFactoryImpl.java:805)
at com.googlecode.genericdao.search.hibernate.HibernateMetadataUtil.get(HibernateMetadataUtil.java:92)
at com.googlecode.genericdao.dao.jpa.JPABaseDAO._all(JPABaseDAO.java:206)
at com.googlecode.genericdao.dao.jpa.GenericDAOImpl.findAll(GenericDAOImpl.java:61)
at org.geoserver.geofence.core.dao.impl.RuleDAOImpl.findAll(RuleDAOImpl.java:101)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:110)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy22.findAll(Unknown Source)
at org.geoserver.geofence.services.RuleAdminServiceImpl.getAll(RuleAdminServiceImpl.java:189)
at org.geoserver.geofence.web.GeofenceRulesModel.(GeofenceRulesModel.java:81)
at org.geoserver.geofence.web.GeofenceServerPage.(GeofenceServerPage.java:63)
… 99 more
On Mon, Oct 19, 2015 at 2:56 AM Walter Stovall <walter.stovall@…4309…> wrote:
Using the latest eclipse and the master branch of geofence. I’m following eclipse setup instructions at https://github.com/geoserver/geofence/wiki/Building-instructions
My problem may be related to the GWT SDK version. I went to https://developers.google.com/eclipse/docs/download to install the latest GWT plugin. But the instructions say to use GWT 2.1.1. So I downloaded and unzipped the gwt-2.1.1.zip file. Then in eclipse I go to Window->Preferences->Google->App Engine->Add and point to my unzipped 2.1.1. But eclipse shows an error “Failed to initialize App Engine SDK at C:.…”. The app engine SDK appears to be a good install – at least creating the sample MyWebApp with it works.
I tried running with the latest SDK but some of the switches in the launch-config arguments are not valid in that SDK – I think this direction is a wrong-turn.
Does anybody know how to get past this?
Looking in the eclipse log I find…
!ENTRY com.google.appengine.eclipse.core 4 0 2015-10-19 05:45:47.604
!MESSAGE GAE SDK gwt-2.1.1 failed validation
!STACK 1
org.eclipse.core.runtime.CoreException: Failed to initialize App Engine SDK at C:\byers\git\GoogleWebToolkit\gwt-2.1.1
at com.google.appengine.eclipse.core.sdk.AppEngineBridgeFactory.createBridge(AppEngineBridgeFactory.java:194)
at com.google.appengine.eclipse.core.sdk.AppEngineBridgeFactory.createBridge(AppEngineBridgeFactory.java:122)
at com.google.appengine.eclipse.core.sdk.AppEngineBridgeFactory.getAppEngineBridge(AppEngineBridgeFactory.java:95)
at com.google.appengine.eclipse.core.sdk.GaeSdk.getAppEngineBridge(GaeSdk.java:325)
at com.google.appengine.eclipse.core.sdk.GaeSdk.validate(GaeSdk.java:498)
at com.google.gdt.eclipse.core.ui.AddSdkDialog.validateSdk(AddSdkDialog.java:273)
at com.google.gdt.eclipse.core.ui.AddSdkDialog.validate(AddSdkDialog.java:213)
at com.google.gdt.eclipse.core.ui.AddSdkDialog$4.modifyText(AddSdkDialog.java:176)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:179)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1137)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1118)
at org.eclipse.swt.widgets.Text.wmCommandChild(Text.java:3071)
at org.eclipse.swt.widgets.Control.WM_COMMAND(Control.java:4824)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4679)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5050)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2443)
at org.eclipse.swt.widgets.Text.callWindowProc(Text.java:260)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4774)
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2671)
at org.eclipse.swt.internal.win32.OS.SetWindowTextW(Native Method)
at org.eclipse.swt.internal.win32.OS.SetWindowText(OS.java:3473)
at org.eclipse.swt.widgets.Text.setText(Text.java:2296)
at com.google.gdt.eclipse.core.ui.AddSdkDialog$2.widgetSelected(AddSdkDialog.java:153)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
at org.eclipse.jface.window.Window.open(Window.java:803)
at com.google.appengine.eclipse.core.preferences.ui.GaePreferencePage$1.doAddSdk(GaePreferencePage.java:90)
at com.google.gdt.eclipse.core.ui.SdkTable$3.widgetSelected(SdkTable.java:242)
at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.open(WorkbenchPreferenceDialog.java:211)
at org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPreferencesAction.java:63)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:595)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:511)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:420)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
Caused by: java.lang.NoClassDefFoundError: com/google/apphosting/utils/config/AppEngineConfigException
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2585)
at java.lang.Class.getConstructor0(Class.java:2885)
at java.lang.Class.newInstance(Class.java:350)
at com.google.appengine.eclipse.core.sdk.AppEngineBridgeFactory.createBridge(AppEngineBridgeFactory.java:189)
… 77 more
Caused by: java.lang.ClassNotFoundException: com.google.apphosting.utils.config.AppEngineConfigException
at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
… 82 more
Geoserver-devel mailing list
Jody Garnett
