I'm trying the rest examples and the following error is shown:
:Unable to transform referenced envelope, crs has not yet been provided.
The command line i'm running is:
curl -u admin:geoserver -XPOST -H 'Content-type: text/xml' -d
'<featureType><name>barrios</name></featureType>'
http://localhost:8080/geoserver/rest/workspaces/Montevideo/datastores/BasePostgis/featuretypes
The Barrios table is a postgis table, the data was transformed from a
shapefile to a sql file in order to insert them into the database.
I try to use the following functions :
select updategeometrysrid('barrios', 'the_geom', 2163);
select setsrid(the_geom, 2163) from barrios;
And then, create the check :
ALTER TABLE barrios
ADD CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 2163);
But the error is still there...
I think the SRS is 2163 but i'm not really sure.
What can be the problem? Anyone can helpme ?
Thanks, Santiago.
View this message in context: http://www.nabble.com/Unable-to-transform-referenced-envelope%2C-crs-has-not-yet-been-provided-tp24541907p24541907.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Santiago Montico ha scritto:
ALTER TABLE barrios
It is hard to tell. Do you have a full stack trace? Also, can you
share sample data to reproduce the issue (by private mail possibly
so that the list is not flooded).
Andrea Aime
OpenGeo - http://opengeo.org
Andrea,
I can share the data with you.
Please send me the email address so i can attach the information (sql
script, can be? ).
Related to the full stack trace you are asking, in the console it shows the
following error:
17 jul 18:10:37 INFO [org.geoserver] - Loaded feature type 'barrios',
disabled
17 jul 18:10:37 ERROR [geoserver.rest] - :Unable to transform referenced
There's another log file where i cant get more information?
Thanks, Santiago.
ALTER TABLE barrios
Andrea Aime
Enter the BlackBerry Developer Challenge
This is your chance to win up to $100,000 in prizes! For a limited time,
vendors submitting new applications to BlackBerry App World(TM) will have
the opportunity to enter the BlackBerry Developer Challenge. See full
prize
details at: http://p.sf.net/sfu/Challenge
Geoserver-devel mailing list
View this message in context: http://www.nabble.com/Unable-to-transform-referenced-envelope%2C-crs-has-not-yet-been-provided-tp24541907p24568904.html
Andrea,
script, can be? ).
This mail address is good, just make sure not to cc the mailing list.
following error:
disabled
$GEOSERVER_DATA_DIR/logs/geoserver.log, but it should contain the
same information as the console
Andrea Aime
Andrea,
Problem solved.
Now i generate the sql file using a specific srid and i could create the
feature type correctly.
./shp2pgsql -s 2163 barrios barrios2 > barrios2.sql
Thanks, Santiago.
Andrea,
script, can be? ).
the
following error:
disabled
Andrea Aime
prize
View this message in context: http://www.nabble.com/Unable-to-transform-referenced-envelope%2C-crs-has-not-yet-been-provided-tp24541907p24570983.html
