[Geoserver-devel] Unique name generation
I’m looking into some REST API improvements and I see there are a few places where unique names should be autogenerated - in the data upload handling we create a new layer and need to ensure it doesn’t have a name clash with other layers in the same workspace; I’d also like to have an option for the data upload to generate a new style, which is also subject to naming conflicts. I was looking at the code in DataStoreFileResource and I see that it just tries all the possible suffixes from 1 to 10 and gives up if that doesn’t work (see line 393 and on for the details.) Might be nice for it to try a bit harder (maybe fetch all layers with the requested name as a prefix and do something smart with the results?)
It also seems like this would be a useful thing to abstract out - I’m thinking of adding a method like
class CatalogBuilder {
public String uniqueName(WorkspaceInfo workspace, String requestedName, Class<? extends ResourceInfo> resourceType)
which would handle that logic in a more centralized location. Any thoughts?
This is relevant to at least these tickets:
http://jira.codehaus.org/browse/GEOS-2635
https://jira.codehaus.org/browse/GEOS-5057
David Winslow
OpenGeo - http://opengeo.org/
+1. I have actually needed this functionality on other projects and had to roll out a method to do exactly this.
On Wed, Apr 18, 2012 at 6:36 PM, David Winslow <dwinslow@anonymised.com> wrote:
David Winslow
Better than sec? Nothing is better than sec when it comes to
monitoring Big Data applications. Try Boundary one-second
resolution app monitoring today. Free.
http://p.sf.net/sfu/Boundary-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
Which projects? Are there other places in the GeoServer code base that should be refactored to use the new API?
David Winslow
On Thu, Apr 19, 2012 at 8:26 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
David Winslow
Justin Deoliveira
Some data import tools, nothing inside of the geoserver code base.
On Thu, Apr 19, 2012 at 10:53 AM, David Winslow <dwinslow@anonymised.com1…> wrote:
David Winslow
On Wed, Apr 18, 2012 at 6:36 PM, David Winslow <dwinslow@anonymised.com…> wrote:
David Winslow
Justin Deoliveira
Justin Deoliveira
