On Wed, Dec 16, 2015 at 10:44 PM, sikeoka <steve.ikeoka@anonymised.com> wrote:
Is there a standard practice for unit testing concurrency issues in
GeoServer? I found an issue in
org.geoserver.wms.featureinfo.HTMLFeatureInfoOutputFormat.getTemplate that
could cause the wrong content template to be used if GeoServer is
processing
multiple WMS GetFeatureInfo requests with HTML output. This could result
in
incorrect output or even errors if the template that gets loaded does not
work with the layer that is being processed.
Hi Steve,
we don't really have much, the few cases I think we used a executor
submitting
a bunch of callables into it, but trying to still keep the test running for
a short
amount of time, e.g.:
https://github.com/geoserver/geoserver/blob/master/src/extension/control-flow/src/test/java/org/geoserver/flow/NestedRequestSentinelTest.java#L45
https://github.com/geoserver/geoserver/blob/master/src/main/src/test/java/org/geoserver/security/filter/GeoServerBasicAuthenticationFilterTest.java#L42
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
