Late Friday trivia. What happens if you specify the following CSS on a freshly built GeoServer trunk?
stroke: blue;
stroke-width: 100m
This:
and then you zoom in:
and then a bit more:
:-p
A great weekend to everybody (and thanks to New South Wales Geological Survey
for sponsoring this).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Cool! Is that liable to work with SLD’s as well?
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
(attachments)
stroke: blue;
stroke-width: 100m
This:
:-p
Ing. Andrea Aime
@geowolf
Technical Lead
DreamFactory - Open Source REST & JSON Services for HTML5 & Native Apps
OAuth, Users, Roles, SQL, NoSQL, BLOB Storage and External API Access
Free app hosting. Or install the open source package on any LAMP server.
Sign up and see examples for AngularJS, jQuery, Sencha Touch and Native!
http://pubads.g.doubleclick.net/gampad/clk?id=63469471&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
On Wed, Nov 20, 2013 at 2:46 PM, Jonathan Moules <
jonathanmoules@anonymised.com> wrote:
Cool! Is that liable to work with SLD's as well?
Yep, just write 10m instead of simply 10.
Mind, it's just available on trunk/master, you'll need to get a nightly
build to try it out.
Hmm... nightly builds do not seem reachable right now though:
http://ares.boundlessgeo.com/geoserver
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks; I can wait until 2.4.3; I guess it’ll be backported for that?
On Wed, Nov 20, 2013 at 2:46 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Mind, it’s just available on trunk/master, you’ll need to get a nightly build to try it out.
Hmm… nightly builds do not seem reachable right now though:
On Wed, Nov 20, 2013 at 3:01 PM, Jonathan Moules <
Thanks; I can wait until 2.4.3; I guess it'll be backported for that?
Definitely not for 2.4.3, there is not enough time, maybe for 2.4.4
Ing. Andrea Aime
@geowolf
Technical Lead
